Air cond. freezing up - JeepForum.com
post #1 of 6 Old 09-03-2003, 10:31 PM Thread Starter
Lodgepole
Have 2000 G.C. and air cond freezes up even with lots of fan and warmer temp setting. I added a little gas and low pressure is about 30. Dealer said possible cycling switch problem. Has anyone had experience with this? Where is this switch? Does the system have to be opened to change? Help please!
Lodgepole
Lodgepole is offline
post #2 of 6 Old 09-04-2003, 07:44 PM
Scottolan
The lower pressure switch is on the Evaporator canister on the left hand side of the engine compartment.. it's usually either painted black or raw aluminum in color.. There is a switch on top all you do is unscrew it and replace it... it has a check valve on the canister itself so you can remove and replace the switch without loosing any freon and without draining the system..
Most freezing up is due to low freon levels..
98 Jeep Grand Cherokee Orvis 318 V8 4x4
So many options it does everything but wipe your ***!
Scottolan is offline
post #3 of 6 Old 09-05-2003, 07:35 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
where can you get them? besides the stealership?
i need the one that goes on the accumulator tank.
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #4 of 6 Old 09-05-2003, 07:44 AM
Scottolan
You can try an auto parts store but I just went back to the dealership for mine... The one I had go out was on my Mustang.. It cost me like $20 for the part from Ford...
Not sure how much Dodge/Jeep will charge you for one
Scott
post #5 of 6 Old 10-17-2003, 02:08 PM
Rooster77
Have any of you guys ever had success in finding this Jeep Cycle switch?
I went to the stealership today to get one cause my A/C is not cycling on and off, it only stays on and yes it is full of freon.
The stealership tells me that the switch does not come seperate but as part of the receiver drier and is $350!!!
Rooster77 is offline
post #6 of 6 Old 10-18-2003, 10:02 AM Thread Starter
Lodgepole
Well Rooster 77, I got a switch only from my dealer for $20. Can remove old one wirhout loosing freon and replace with just your hand. It seems to have cured the problem although I installed it late in our season and haven't taken any long road trips. I think some dealers are out to give you the ROYAL SCREW. I had a Dodge dealer Part # is4897613(5 star) ask me $700 for a 2002 Ram 17 in steel wheel with the chrome overlay. I reported it to the sales manager and he got real upset. I told him his parts department had just alienated a customer. They just don't get it. Part # is 4897613-AB/ 8059051. $19 + tx.
Lodgepole
Its FREEZING in NY but its colder is my JEEP aog22 ZJ Grand Cherokee Forum 16 01-18-2010 04:08 PM
A/C Freezing my foot...Need Modification! Kaliber35 WK Grand Cherokee & XK Commander Forum 2 08-16-2009 07:03 PM
freezing jeep cherokeehair ZJ Grand Cherokee Forum 51 01-28-2009 08:48 AM
air cond. only blowing threw ceenter vents 2000 wj ZJ Grand Cherokee Forum 20 07-17-2007 08:37 PM
air cond. Lodgepole WJ Grand Cherokee Forum 3 08-19-2003 01:04 PM
