Air bag light on. Diagnose? - JeepForum.com
post #1 of 17 Old 10-11-2011, 03:54 PM Thread Starter
gamble
Anyway to diagnose this without paying the dealer ? It's ALWAYS on, doesn't matter if you turn the wheel or have the seat belts buckled in or not. Or if anyone knows how to reset it for the time being.
98 ZJ -4.0L
Lots of welders and cnc table
gamble is offline
post #2 of 17 Old 10-11-2011, 04:18 PM
orb
2003 WJ
You can reset it by taking off the negative battery connection but it will come back if there is really something wrong.
2003 4.0L, OME HD Springs, OME Nitro Shocks, Rancho SS, 265/70R16 General Grabber AT2s
orb is offline
post #3 of 17 Old 10-11-2011, 04:21 PM Thread Starter
gamble
I just had it off a few days ago when I changed out the pcm. Is there a proper procedure for doing this?
98 ZJ -4.0L
gamble is offline
post #4 of 17 Old 10-11-2011, 04:26 PM
orb
2003 WJ
Maybe it's only for CEL lights and not airbag? Does it have a code associated with it? Try this and see what it says:
Originally Posted by wjjeeps.com
Retrieving codes:
Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
I left my neg terminal disconnected for about 20 minutes and that cleared my code after I fixed the issue. I think the proper way would be use an OBDII to clear it but then again, maybe it only for CEL like I mentioned above.
orb is offline
post #5 of 17 Old 10-11-2011, 04:43 PM Thread Starter
gamble
I'm 90% sure the code scanner is only for obd2 codes, I'll plug in my scanner tonight, But I have tried the key method and it says done. No codes are present.
98 ZJ -4.0L
gamble is offline
post #6 of 17 Old 10-11-2011, 05:10 PM
GrandAZ
The clockspring is most likely the culprit of this...
http://www.amazon.com/Dorman-525-108-Clock-Spring/dp/B003GAQ2VM/ref=au_pf_pfg_s?ie=UTF8&Model=Grand%20Cherokee|349&n=15684181&s=automotive&Make=Jeep|42&Year=2000|2000&newCar=1&carId=001
GrandAZ is offline
post #7 of 17 Old 10-11-2011, 09:26 PM Thread Starter
gamble
Damn it, I'm a dummy. Last week I was looking at the fuses and pulled the one for the airbag (one with the big yellow piece) and didn't put it in all the way. Doh!
98 ZJ -4.0L
gamble is offline
post #8 of 17 Old 10-11-2011, 11:27 PM
MeanGreenZJ
You saved yourself some money and work by not throwing a clockspring at it like most people do.
MeanGreenZJ is offline
post #9 of 17 Old 10-11-2011, 11:31 PM
jomps
nice catch...i really got something wrong with mine...
jomps is offline
post #10 of 17 Old 10-11-2011, 11:41 PM
mtb_crzd47
Sorry to hijack but if the light is on but cruise and horn still work is it the clock spring or somethin else? I searched and didn't find a definite answer and didn't want to start a new thread to have 48395 people tell me to search.
Sent by your mother via my Garminfone
2000 WJ LTD Shale Green metallic, stock for now
2007 Yeti AS-X, Avid Code 5's Rockshox Totem,
SOLD: 91 XJ
mtb_crzd47 is offline
post #11 of 17 Old 10-11-2011, 11:42 PM
jomps
id like to know that too
jomps is offline
post #12 of 17 Old 10-12-2011, 12:08 AM
GrandAZ
My light is on but both cruise and horn still work and I've been told it is still the clock spring ......
GrandAZ is offline
post #13 of 17 Old 10-12-2011, 12:41 PM
jomps
thats what im thinking but have problems greater than that right now
jomps is offline
post #14 of 17 Old 06-30-2015, 12:17 AM
Jalandub
My airbag light is mostly on but with certain turns will turn off for a few seconds before dinging back on. So I figured it was the clock spring. Just switched it out and now it's permanently on. So frustrated! I got the part from a pick-a-part but I couldn't have 2 clock Springs. Universe ain't that mean right? Plus my radio controls are less glitchy now so it's gotta be a better clock spring.
Jalandub is offline
post #15 of 17 Old 06-30-2015, 01:30 AM
Johnyre
Have y'all gotten the recall for the passenger air bag blowing up randomly
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
ok i have the typical 4.7 tick, can't diagnose it! 04ovrland WJ Grand Cherokee Forum 17 01-25-2016 01:47 PM
Help Diagnose Problem... jasandalb WJ Grand Cherokee Forum 4 02-25-2011 03:50 PM
Oil pan is off, how to diagnose engine noise? MNWJ WJ Grand Cherokee Forum 9 01-28-2011 09:04 PM
Help me diagnose a rattle/clunk RobertTF WJ Grand Cherokee Forum 3 01-14-2011 12:17 AM
can anyone help me diagnose an ignition problem? woogie WJ Grand Cherokee Forum 7 10-28-2010 12:22 PM
