Air Bag Light - JeepForum.com
post #1 of 4 Old 10-28-2013, 10:58 AM Thread Starter
jonw8192
Wj Air Bag Light
Just bought my 1999 WJ a few weeks ago and now I found out that my Air Bag light has just turned on as well as a check engine light. Figured the engine light was just for an O2 sensor but the Air bag light is worrying me. I am hoping it is a easy fix as my car is due for inspection. The driver seat has a broken mounting bracket and my seat rocks like crazy when Im driving also there is a loose sensor underneath my seat. Could either of these be the cause to the air bag light being on?
jonw8192 is offline
post #2 of 4 Old 10-28-2013, 11:37 AM
seymourless
Check the fuse(s) under the dash. My air bag light was on because the fuses had massive corrosion on them, but was not blown. The two fuses live in a yellow contraption on the right hand side of the fuse box Cleaned the fuses off, now no air bag light!
Hope this helps!
seymourless is offline
post #3 of 4 Old 10-28-2013, 12:03 PM
Merc1973
Can be any of these: Clock Spring, ACM (airbag control module), Front impact sensor.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #4 of 4 Old 10-28-2013, 03:48 PM
rdkendrick
2003 WJ
Depending upon the version of ACM. The later version negates the front impact sensors.
The problem with mine I found out, AFTER I bought a scanner that reads SRS codes, and already replaced the clock spring, was somewhere in the side impact sensor circuit, there was a short. The short turned out to be in the ACM. I had the latest version (AH), but it must have gone bad. The ACM that I ordered was an ( AG), but still worked and got rid of the airbag light.
Sent from my iPad using my fingers
rdkendrick is offline
