Ahhh!!! California Emissions 1999wj - JeepForum.com
post #1 of 9 Old 03-15-2010, 09:00 AM Thread Starter
spgeid
I bought a 1999 GC limited with 40k original miles. Think I got a deal but knew the exhaust was bad when I got it. Turns out it has a california exhaust on it with three catalytics. What a mess finding the front catalytics and worse yet getting them off. I had to pull the front drive shaft to get them down out of the engine compartment. Wish someone made a conversion to change it to a one cataylitic system. Anyone else ever have this headache?
spgeid is offline
post #2 of 9 Old 03-15-2010, 09:17 AM
Technohead
I would not be surprised if there is (alot) more to it than just swapping the pipes.
-Eric
Technohead is offline
post #3 of 9 Old 03-15-2010, 09:35 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I just had the exhust pipe with the 2 mini cats changed on my '04. I bought what was suppose to be a direct replacement from NAPA. It looked like it was, but when the mechanic at the dealer tried to install it he ran into all kinds of problems because it was not made/bent correctly. I have to go back today as he has the exhust skewed and the muffler is hitting on the frame.
I am going to call NAPA and see if I can get a refund and buy the one from the dealer, cost a couple of hundred more but worth it if it fits correctly, after all the problems with the NAPA one.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 9 Old 03-15-2010, 10:08 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Yea, the engine computers and wiring harnesses are different.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 9 Old 03-15-2010, 10:37 AM
LordHobbit
I've never had good luck at NAPA or with NAPA parts.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 9 Old 03-15-2010, 03:19 PM Thread Starter
spgeid
Got the replacement tonight
I got an eastern catalytic direct fit replacement. Cost $319.00 Hope it fits. And of course the hole in the Y pipe was right at the boot on the front drive shaft CV joint. Melted it. Went today and got the bad news that they have to do a remanufacture to change it $180 bucks. Yuk. Talked to a drive shaft repair shop he says he can make me a conventional shaft if the ends on the punkin and quadra drive are the right splines. Not sure which way to go.
spgeid is offline
post #7 of 9 Old 03-16-2010, 07:11 AM
michiganmaveric
Got Beer?
2011 JK Wrangler
Let us know how it goes in, if it bolts right up or not. What is the eastern direct fit, is eastern the name of the company or what? Mine from NAPA I think was about $365.
Lifetime member #13
post #8 of 9 Old 03-16-2010, 10:00 AM Thread Starter
spgeid
Got it on
It bolted on ok. It was quite a fight for a while the spread of the two flanges was off about 3/8" to narrow. I put the back flange on snug and used a pry bar to spread it enough to slide up over the manifold flange. After it was spread the right amount it kinda popped right up on and I was able to get the bolts back in. Tought job for one guy but I was able to get it. Eastern Cataylitic is the manufacture. They are located in PA. I googled it and found a supplier in NY to buy it from. Total shipped bill was right around $325 deliverd UPS in two days. If I was to do it again I might research Catco instead. Not sure and hope I never have to do it again.
spgeid is offline
post #9 of 9 Old 03-16-2010, 12:08 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
The spread was the same problem the mechanic had with the NAPA one, off about the same amount.
Lifetime member #13
excessive vibration and other issues...1999WJ bobbersdown ZJ Grand Cherokee Forum 3 12-29-2009 12:22 PM
California Emissions ecu and emissions bjl95mustang ZJ Grand Cherokee Forum 0 07-13-2008 02:11 PM
98 zj with California emissions system. Do I need a special replacement cat? bjl95mustang ZJ Grand Cherokee Forum 8 12-16-2007 10:05 AM
YCF - California Emissions Order Code bjl95mustang ZJ Grand Cherokee Forum 5 01-26-2006 07:40 PM
Still Failing Emissions in California... dpierson ZJ Grand Cherokee Forum 46 07-26-2005 09:22 AM
