After Alignment Shops says I need an adjustable Ball joint - JeepForum.com
post #1 of 7 Old 03-26-2012, 04:34 PM Thread Starter
MWyatt
Replaced my broken tie rod and took the jeep to get aligned. The shop said I needed an adjustable ball joint to get my camber(caster?) cant remember which. On the alignment sheet it was barely out of spec. Can anyone give me some insight on this?
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #2 of 7 Old 03-26-2012, 05:33 PM
SkipStr
It depends on which way it is out and what the difference side to side is. Generally a difference side to side of more than half a degree may causes a drift or pull( Camber or Caster).
Camber that is out may cause excessive tire wear and a pull if there is a difference side to side.
Caster is a non tire wearing angle. It aids in returnabilty of the wheels and provides high speed stability. It can cause a pull if there is a difference side to side.
They do make after market ball joints that are off center that when rotated will adjust caster and camber. On a solid axel like a WJ, if either is out of spec, something is probably tweaked.
If it is driving straight and camber is not way out, I wouldn't sweat it.
Skip
SkipStr is offline
post #3 of 7 Old 03-27-2012, 06:56 PM
WJ04
Are you still running the stock track bar? when I first lifted my WJ I was told the same thing, that my camber was off and I needed an offset ballpoint. All I did instead was get a jks adjustable track bar installed it then took the jeep back to see if anything changed. My alignment turned out perfect, not really sure why or how the track bar fixed it but that was the only thing I did and it seemed to work. Just a thought.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #4 of 7 Old 03-27-2012, 09:35 PM Thread Starter
MWyatt
I have plans to get a JKS adjustable track bar soon. I have the one that came with the IRO 3" springs but have .75" spacers on as well. Ill try to look at my spec sheet and see how much it really is off and post with the info.
MWyatt is offline
post #5 of 7 Old 03-28-2012, 08:19 AM
WiCkeDuDe
WiCkeDuDe's Avatar
A trackbar will not change the chamber at all. Ive seen brand new WJs that the camber was out of spec due to the axles shifting when they welded them up. If it doesnt pull and isnt wearing the tire down then dont worry about it.
Otherwise install a offset balljoint to get the chamber back to where you need it.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #6 of 7 Old 03-28-2012, 01:40 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
The problem lays with the alignment techs, not the track bar. If they got different results pre- and post- track bar then the techs are incompetent. Find a new shop.
~Richard
billzcat1 is offline
post #7 of 7 Old 03-28-2012, 01:55 PM
USFORCES
^This, also if you can find a shop with the lastest aliment machine some shops use pretty old ones.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
Adjustable Ball joints...anyone use them? Alignment questions r_kelly252 WJ Grand Cherokee Forum 7 08-08-2011 07:34 PM
WJ adjustable ball joints dave01 WJ Grand Cherokee Forum 10 06-30-2011 02:31 PM
adjustable ball joint. can you REINSTALL it? ronsaun WJ Grand Cherokee Forum 10 05-25-2010 11:24 PM
03wj ball joint questions adjustable/deg/upper or lower ronsaun WJ Grand Cherokee Forum 0 05-18-2010 01:09 PM
