Adjusting HID headlights - JeepForum.com
post #1 of 9 Old 09-18-2013, 09:46 PM Thread Starter
D-n-Tyke
I just got my new Spyder HID headlight projector housings installed on my WJ. Unfortunetly out of the box they are aimed to high. Lights up the road and signs awesome, but I am sure I am pissing a few people off. So I am trying to figure out how to adjust them. I found a picture on Spyder Auto's website that points to an "adjuster". My question is which way do you turn the screw to adjust it down, and which way to adjust it up? How much adjustment is there per turn? How much luck have you guys with these housings had with that adjuster?
2002 WJ 4.7 4x4 Limited
D-n-Tyke is offline
post #2 of 9 Old 09-18-2013, 11:05 PM
nmay
I'd park it on level ground, aim at a garage door, solid wall, or something along those lines, turn them on and go from there?
nmay is offline
post #3 of 9 Old 09-19-2013, 12:40 AM Thread Starter
D-n-Tyke
Yeah, that is what I planned on doing. The problem is you have to remove the housing each time you want to make an adjustment to that screw so I was hoping to know which way turning the screw moves the projector.
D-n-Tyke is offline
post #4 of 9 Old 09-19-2013, 02:02 AM
CrazyWalnut13
Point jeep at wall with headlights on. Decide how much you'd like to raise/lower the beam. Pop headlight out and leave wiring connected and headlights on. Hold headlight still with one hand while twisting with the other until desired change in height is achieved. It's not rocket surgery.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #5 of 9 Old 09-19-2013, 05:40 AM
imaguy3
I was able to leave mine in the car and adjust... a long philips screwdriver reaches down there and you're able to teeth on the gear engage the screwdriver. However it's SLOW going as the adjustments are fine and if you're not holding the screwdriver just right you'll just slip it on by... I find I needed to apply some sideways tension when I did it in order to keep the screwdriver engaged.
If you look in your picture, at the top of the wheel are two plastic tabs... the screwdriver fits right between them.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #6 of 9 Old 09-19-2013, 08:42 AM
Merc1973
Read here for alignment on a wall: http://wjjeeps.com/lamps/headlamps.htm
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #7 of 9 Old 10-06-2013, 06:52 PM
209jeepdude
If you are standing voer your Jeep and peer down through the hole. The wheel adjustment going away to your right lowers them and to your left raises them
209jeepdude is offline
post #8 of 9 Old 10-06-2013, 08:11 PM
jcool1985
The OP has aftermarket lights so he does not have the standard adjusting screw as we do on our headlights. To the OP that is a crazy design though that you have to remove the light to adjust. Not very well thought out on the manufactures part.
jcool1985 is offline
post #9 of 9 Old 10-07-2013, 06:28 AM
spud2388
you dont have to remove the headlights to adjust them. The adjuster (red circle) is designed to take a screwdriver from the side. Thats what the little guides are above it. They keep the screwdriver in place so you can turn it. If you want to take the headlights off to see how it works, you can. Just takes a phillips head and your set.
spud2388 is offline
