Addco Rear Sway bar installation question.. - JeepForum.com
post #1 of 5 Old 06-20-2013, 07:09 PM Thread Starter
qbny94
I'm having trouble removing the bolt for the sway bar end links because they are rusted and I don't have room for my impact wrench due to my tires and gas tank skid plate. I was hoping not to jack up my rear but should I just jack it up and remove my rear tires for better access? I already sprayed WD-40 on the bolts and that didn't work. Any other tips without having to jack it up?
qbny94 is offline
post #2 of 5 Old 06-20-2013, 07:23 PM
adavis39
Mix 50/50 acetone and atf.......will work 100 times better than wd40
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #3 of 5 Old 06-21-2013, 09:43 AM
85IrocZ-28
^ Words of Wisdom
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #4 of 5 Old 06-21-2013, 10:13 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
What those guys have said. WD-40 is NOT a penetrating oil. It does nothing at all to rust. And take the extra minute to jack up the rear and remove the tires. Life will be much easier that way.
~James
ezflip is offline
post #5 of 5 Old 06-21-2013, 11:35 AM
Meta4
2010 WK
I'm surprised you're having trouble with the end links. I was able to get them off my Jeep last night with a socket wrench. The nut will start turning when you break it free so you'll need a pair of pliers or another wrench to keep it from spinning.
If the end link bolts are giving you trouble, be ready for some serious pain with the bushing bracket bolts. Those things were a complete PITA to get out even with penetrating oil and an impact wrench.
2004 Jeep Grand Cherokee Overland
Meta4 is offline
