-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Actual lift height (http://www.jeepforum.com/forum/f310/actual-lift-height-1613721/)
kaleo333 09-22-2013 10:35 PM
Actual lift height
I was looking at a lift for a 2004 Jeep Grand Cherokee special edition. On the build sheet it says that there is a 1" upcountry package. How could I confirm the current lift height? I just want to know if a 2" lift will only yield one inch of difference compared to what it currently on it and has this current package sagged. Thanks in advance.
Hack 09-22-2013 10:57 PM
If you're lucky there will still be paper tags on the springs with the part numbers. Many of the later Upcountry packages were mistakenly ordered without the springs so its worth checking. There are some measurements from hub to fender with stock springs floating around the forum. I don't remember them off the top of my head though, sorry.
kaleo333 09-22-2013 11:02 PM
those hub to fender measurements are probably what I'd be looking for. but thanks for the info about the kit. If it was one inch above the stock height, would any lift yield one inch less than advertised?
bradywgn71 09-22-2013 11:13 PM
Up Country package discontinued for all models as of August 31, 2003
All models built after August 2003 were no longer offered with the Up Country package, the special shocks and springs were discontinued. Skid plates and tow hooks, formerly included with the Up Country package and also available separately, became standard on the Overland and optional on all other models.
http://www.wjjeeps.com/upcountry.htm
Measure from the center of the hub up to the fender lip:
Standard springs 18" F 19" R
Up Country 19" F 20" R
alfaitalia 09-23-2013 05:11 AM
Just for info, uc suspension was standard on euro spec models, at least the diesels, until the end of production.....which was actually 2005 rather than 2004 in Europe!
Sent from the Dark Side using only the Force.
cubalz 09-23-2013 12:50 PM
I agree with Hack. Find what you are looking for at this link:
kaleo333 09-23-2013 08:31 PM
So an 04 that sits at 18 1/4 in the front and 19 in the rear, would sit at 20 1/4 and 21 respectively, with a 2 inch BDS lift since this year didn't come with the "upcountry 1 inch lift"? Sorry I just want to clarify before such as I purchase
kaleo333 09-23-2013 08:32 PM
Before such a big purchase
MuddyWJ 09-24-2013 06:42 PM
Si Senor. You'll want to replaced the isolators.
The time now is 03:38 PM.
