Accessing Dana 44 top bolts - 2002 WJ - JeepForum.com
post #1 of 3 Old 06-09-2017, 07:40 AM Thread Starter
johnobub
Need to change gear oil on a 2002 WJ, what is the best way to remove the Dana 44 cover? Do I need to remove the rear sway bar and fuel skid to get at the top bolts of the Dana 44?
johnobub is offline
post #2 of 3 Old 06-09-2017, 07:46 AM
ChrisHager
Administrator
ChrisHager's Avatar
If you jack the vehicle up by the "frame", your axle will droop and allow you to access the top bolts...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 3 Old 06-09-2017, 08:44 AM Thread Starter
johnobub
Sounds good. Ok, thanks.
johnobub is offline
