access to flexplate bolts? - JeepForum.com
post #1 of 4 Old 07-17-2013, 04:14 PM Thread Starter
multmigs
2003 WJ
I have had this tick tick engine noise ever since replacing my engine (03 V8) which is clearly coming from the area of the bellhousing. I was told by several people that the flexplate bolts could be loose or the flexplate itself cracked. I removed the inspection cover for the flexplate and was able to rotate engine by hand to check all the bolts that attach the flexplate to the torque converter. All were tight and the portion of the flexplate i can see seems ok. I told someone I did this who then responded "what about the bolts on the end of the flexplate to the crankshaft? I had already put the cover back on and didn't remember that I could see anything like that because the TC is obviously pushed right up against the flexplate. My question is could I unbolt the flexplate to TC and then push the TC back towards the transmission enough to be able to get a socket or wrench up into the gap to check? I can't recall what it looked like when the 2 came apart before.
multmigs is offline
post #2 of 4 Old 07-17-2013, 07:41 PM
USMC_XJ
2003 WJ
No. Is the simple answer. There is no way to get to those bolts unless you pull apart the engine and transmission. There are 8 bolts holding the flywheel onto the crank. Did the engine already have the flywheel bolted to it? Are you sure the engine was good and not knocking? Just a thought.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #3 of 4 Old 07-17-2013, 08:44 PM
imaguy3
Exhaust leaks cause a ticking sound... Mine is on the rear driver side exhaust port. It's near the transmission/engine coupling and the noise can sound like it's coming from that area. It's easy to check those manifold bolts and see if any are broken causing the leak, plus it's much much more common of a problem...
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #4 of 4 Old 07-18-2013, 04:24 PM Thread Starter
multmigs
2003 WJ
I replaced the engine myself with a reman longblock. The trans had no problems when i last drove it and exploded the engine. I removed the flexplate from old motor it appeared to be free of cracks etc, just cleaned it up and bolted to new engine. I believe I used thread locker on those bolts and tightened them in a star pattern to the FSM torque before reinstalling engine onto old trans. There is no exhaust leak i replaced all those bolts with new ones and obviously used new gaskets etc, i have had the motor running with the inspection cover removed and its very clear the clicking noise comes from something in that flexplate area. I've been running it like this for almost a year, motor went back in last August and i've driven it aprox 4k miles in that time with no problems from trans or engine. Just hate listening to that sounds its super annoying in a drivethrough when i get my Chik Fila on for instance.
multmigs is offline
