AC vents only blowing half the air they should - Page 4 - JeepForum.com
post #46 of 52 Old 08-24-2013, 02:25 PM
scotty94
Wj
hello all...I am in a bad way...fan motor blowing hard but hardly no air coming from my 04 overland....air is cold coming out...blows just a little harder on the driver side than the passenger side...I have read a lot of things could be wrong...where should I start?...any help will be grately appreciated....my second jeep also...just got it today!!...loved it so much the first time I regreted getting rid of ol' "bossy"....
scotty94 is offline
post #47 of 52 Old 08-24-2013, 03:45 PM
SirCussFreq
I've been having some issues with the airflow, so I crawled under my glove compartment and found the connector with the infamous reversed wires... It's already got the green wires spliced in, so I assume it had the resistor replaced sometime in the past.
I unplugged it and swapped the wires on each side, then when I plugged it back in it blew the fuse in the PDC. I ran to Autozone and picked up a couple 40A spares, as soon as I plugged the new fuse in it blew the fuse again. I swapped the wires back around, but when I plugged in the second new fuse, it also blew instantly. So now I'm stuck with no air at all.
What am I doing wrong? Little bastards are $5 each so I don't want to blow too many more...
SirCussFreq is offline
post #48 of 52 Old 08-24-2013, 05:19 PM
scotty94
well sircuss freq...I am not sure whats going on with yours...I really hope someone can help us with our problem...I found kolak on facebook and sent him a message...he is the jeep jedi...I sure hope he can use the force and get us some "force" back on our air problem issue
scotty94 is offline
post #49 of 52 Old 08-24-2013, 07:10 PM
SirCussFreq
Bah... turns out I'm a moron and wasn't paying enough attention! I swapped the wires in the 3 wire connector, not the 2 wires that run from the controller to the blower itself. Oops. Guessing I fried the control module, hopefully that's all I messed up.
post #50 of 52 Old 07-26-2014, 11:08 PM
DeucesALLin
Tried a 250cfm marine blower...
Jabsco 12v 250cfm flange mount blower lines up easily...dont waste your time. looks like a glovebox mounted turbocharger.
Also taped the ducting and fixed recirc, as well as cut a bigger factory intake. Then went to diffrent blower setups.
Next stop: Rear AC
DeucesALLin is offline
post #51 of 52 Old 03-16-2015, 05:00 AM
jeffjeep2
Wj
did the resistor in mine when I replaced the resistor if does blows good,
i wanna clean the evap from the blower location its.
i wanna fix the recirc window i dont want to use air from outside what should be the position?
Thanks
2007 Compass
2000 WJ QD now working
ZJ 4.0 I6 sold ( i miss it)
jeffjeep2 is offline
post #52 of 52 Old 06-22-2015, 08:32 PM
sdjp
sdjp's Avatar
This is a great thread with a lot of useful information; I've replaced my blower motor a couple years ago when it blew with a rock-auto one and it brought me back to the standard crappy performance of an 02' WJ. I'm going to check on all the seals and check on the motor fins to see if I should reverse my wires.
I have small kids that ride in the back and it gets nasty hot back there during summer. I've been using Walmart-type battery powered water spray bottles hanging on the roof handles to help cool things out; cheesy but better then nothing. Hey kids wanna go on an offroad adventure?......(kids)....umm in that sweatbox no thanks dad. If I ever get time and am feeling creative I'd be all about putting in a backseat AC system to really make me proud of owning the WJ.
sdjp is offline
No Heat blowing from vents, but can feel warm air. JPerksR6 ZJ Grand Cherokee Forum 8 02-06-2010 08:02 AM
problems with air blowing only through my defrost vents joshhuwa ZJ Grand Cherokee Forum 1 07-19-2008 09:45 PM
Air not Blowing from vents? 93' Grand Cherokee stylezprodukz ZJ Grand Cherokee Forum 1 11-22-2007 11:50 AM
Defrost not working, blowing out vents instead mattadams ZJ Grand Cherokee Forum 8 11-27-2006 01:52 PM
A/C Vents Blowing Water? cajunc4 ZJ Grand Cherokee Forum 2 08-06-2003 12:29 PM
