Ac not working - JeepForum.com
post #1 of 8 Old 08-22-2013, 02:54 PM Thread Starter
rfritz7
Ac not working
My ac only blows cold on the highway. I just got it charged about 2 weeks ago.
rfritz7 is offline
post #2 of 8 Old 08-22-2013, 03:08 PM
jclaudii
Does it need charged again? How about cooling fan?
jclaudii is offline
post #3 of 8 Old 08-22-2013, 07:29 PM Thread Starter
rfritz7
I don't think it needs charged again it just was. And Cooling fan is running strong
rfritz7 is offline
post #4 of 8 Old 08-22-2013, 09:33 PM
jclaudii
We need more info. Do you have access to any gages?
jclaudii is offline
post #5 of 8 Old 08-22-2013, 09:47 PM
Sandhara
Is your condenser all plugged up with crap restricting too much air flow at low speeds? That's my best guess with this little info. Did you have a shop charge it or did you do it from one of those recharge cans?
99 Wrangler Sahara 5spd manual - Mine
08 Patriot sport 4x4 auto - Wifes
92 Cherokee Lorado auto - for when mine needs fixin/winter beater
Im sorry, some times i drink and post stupid comments.
Sandhara is offline
post #6 of 8 Old 08-22-2013, 11:35 PM
rdkendrick
2003 WJ
Sounds like the evaporator is freezing up.
Sent from my iPad using my fingers
rdkendrick is offline
post #7 of 8 Old 08-23-2013, 06:33 AM Thread Starter
rfritz7
The gauges all reading a little high with the charge they put in. It might be freezing up like you said
rfritz7 is offline
post #8 of 8 Old 08-23-2013, 11:01 AM
1hotrod
It shouldn't freeze up from an overcharged system, this usually happens on an undercharge. How much over are the pressures? Your compressor is most likely weak, especially if the low side is high at idle, say 50psi or more. Look at the low side line it should be sweating, if not your overcharged or your compressor is shot.
1hotrod is offline
