Absolute best spark plugs for '04 Grand Cherokee Laredo.... - JeepForum.com
post #1 of 57 Old 01-24-2009, 05:52 PM Thread Starter
KDOG2008
Hi there, I've been out of here for awhile so I apologize if this is a redundant post....
Well its about that time I'm almost at 60K, so I'm gonna go ahead and do this before I go on vacation in April. I recently purchased a camper so I want to squeeze every little bit of power and efficiency out of my beast. I've heard positive things about Bosch Platinum +4s' - like they put out the best "bang" - to negative like they're junk and the tips break off into the cylinder. I've heard of Iridiums, but don't know much about them.
So I'll ask all you car peeps, what would be your choice for spark plugs? Cost isn't an issue since its only done once every great while. As far as the other stuff I use, I use Mobil 1 full synthetic oil and K&N air and oil filters.
Also do changing to high end spark-plug wires make any difference? Thanks for any help you can give me...
KDOG2008 is offline
post #2 of 57 Old 01-24-2009, 05:54 PM
gatorayde
search, this has been asked and discussed many times.
gatorayde is offline
post #3 of 57 Old 01-24-2009, 06:04 PM
melloyello
Best plugs I have ever seen for any internal combustion engines are NGK
But, IMHO, just stay clear of Autolite (aka. JUNK)
melloyello is offline
post #4 of 57 Old 01-24-2009, 06:12 PM
dmolaver15
i tried the bosch +4 thingys, they made my jeep run like a 3 legged dog on acid..
brand new set of champion copper cores are the best from what i've heard, BUT i've also been hearing about NGK plugs lately and that they're supposed to be very nice to jeep engines as well. i bought a set of NGK's from autozone about a week ago but i'm still waiting for the damn heep to come back from the dealer (grenaded rear end) to give them a try.
04 WJ 4.0
6.5" IRO Front and Rear Longarms
Soft 8's, 285/75/16 BFG Mall Terrains
Super 44 with 3" Side Dump
Dana 44a, 4.56's
My Build Thread:
dmolaver15 is offline
post #5 of 57 Old 01-24-2009, 06:59 PM
Eroc147
2014 JK Wrangler
copper, must have copper, jeeps dont like that expensive crap, so be happy save a few bucks and your jeep will run better too!
2014 JKURX, 2014 GC WK2 4x4 Summit Hemi; 2004 Grand Cherokee Overland, 2"bb, 31" bfg mt km2s
Eroc147 is offline
post #6 of 57 Old 01-24-2009, 08:08 PM
Turbonut
You ain't gonna see any difference with spark plugs, regardless of cost, so stick with the stock plugs, and good luck with plug wires!!!!!!!
http://www.wjjeeps.com/service/sparkplugs.htm
Q: How much of a performance improvement can I expect from changing plugs?
A: A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
Turbonut is offline
post #7 of 57 Old 01-24-2009, 08:12 PM
melloyello
I was recommending NGK's for their durability and long life, not as a power increase but just a form of preventitive maintenance and a better piece of mind.
post #8 of 57 Old 01-24-2009, 08:14 PM
gatorayde
Spark plugs are cheap (at least for the 4.0's and going with the tried and true copper cores), swapping them out every 50-60k doesn't cost much so why waste it on NGk's...
post #9 of 57 Old 01-24-2009, 08:24 PM
melloyello
I don't like to break down, so I run NGK's. Personal preference. Never had one quit b/4 it was scheduled to be replaced.
post #10 of 57 Old 01-24-2009, 08:53 PM
Turbonut
Put a set of NGK Iridiums in or modified RX7 Turbo, but in 670 miles one trailing plug stopped firing. Went back to the factory NGK's and no problems before or after.
Turbonut is offline
post #11 of 57 Old 01-24-2009, 08:55 PM
StrokedWJ
StrokedWJ's Avatar
As others have said, the best and recommended plug for the 4.0 is the cheap base model copper cores. The 4.0L does not benefit from the high end "fancy" plugs. And in some cases the more expensive plugs make 4.0s run like crap.
BTW, your WJ does not use plug wires. They use a distributor less system with a coil pack rail over the plugs.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #12 of 57 Old 01-24-2009, 09:08 PM
melloyello
To each his own.
post #13 of 57 Old 01-24-2009, 09:11 PM
gatorayde
To each his own.
So true about the spark plug topic.
post #14 of 57 Old 01-24-2009, 10:02 PM
comptiger5000
I've heard many stories about plugs for 4.0s. It seems that some Jeeps like certain plugs better than others.
comptiger5000 is offline
post #15 of 57 Old 01-25-2009, 08:08 AM
ZeeJay1997
There are absolutely no absolutes.
ZeeJay1997 is offline
04 grand cherokee with HO spark plugs? GoneHuntin ZJ Grand Cherokee Forum 6 02-01-2008 07:11 PM
Spark Plugs, 04 Cherokee 4.0 tomt39 ZJ Grand Cherokee Forum 3 03-21-2007 12:09 PM
'95 Grand Cherokee - changing spark plugs jeep95 ZJ Grand Cherokee Forum 17 06-12-2006 05:34 PM
best spark plugs for 1993 Grand Cherokee inline 6 cycl.? 93JGCsnomobile ZJ Grand Cherokee Forum 15 09-08-2005 06:09 AM
Add-ons for a 93 Grand Cherokee Laredo Rdsxbaseball ZJ Grand Cherokee Forum 4 03-23-2003 12:40 PM
