ABS light goes on then off? - Page 2 - JeepForum.com
post #16 of 24 Old 09-17-2013, 10:00 PM
86cj74.2L
86cj74.2L's Avatar
Mine were broken wires.
If you plan on keeping the WJ its worth having a more advanced scanner that reads ABS, and manufacture specific (special) codes.
86cj74.2L is offline
post #17 of 24 Old 09-18-2013, 11:26 AM
Starboard M
Not to sound like too much of an idiot, but is the ABS sensor easy to get to with the wheel off?
Mine does the same thing as the OP. I thought it was weather related as the ABS light seems to go off when its above 80*, but stay off when below.
Originally Posted by NoVaHunter View Post
Honestly, its dicks like you that make unnecessary comments via the internet that have no impact what so ever.
Starboard M is offline
post #18 of 24 Old 09-18-2013, 11:50 AM
DustinWJ
Ya should be bolted to each side with a tiny bolt. Loosen And it should pop out
DustinWJ is offline
post #19 of 24 Old 09-18-2013, 03:05 PM
MeanGreenZJ
What's the plan? Swap them out one by one till you get lucky?
MeanGreenZJ is offline
post #20 of 24 Old 09-18-2013, 03:48 PM
86cj74.2L
86cj74.2L's Avatar
Either get a scanner that scans for abs.
Or using a volt meter you can test them using the resistance or AC setting (with the AC setting you spin the wheel) However you most likely won't see anything if the abs light isn't on. Unless you jerk and twist the cable while spinning the wheel and look for the signal to drop out.
post #21 of 24 Old 09-18-2013, 07:20 PM
MeanGreenZJ
Spinning the wheel past 50 or even 80mph (as per post #17)?
post #22 of 24 Old 09-18-2013, 08:12 PM
Lustra
Junior Member
i can see how that would be a problem
_______________________________________
Originally Posted by newfieZJ
We may have gotten off to a bad start , but , you are one ignorant SOB
Yes , the mileage is stored in the PCM , it's only available through a DRB scan, it is irrelevant to 99% of jeepers
What about the other 1%?
Silly Hillbilly
Lustra is offline
post #23 of 24 Old 09-18-2013, 08:22 PM
86cj74.2L
86cj74.2L's Avatar
No, you unplug the connector and hook your meter to the pins.
Then read ohms
Or you can flip to AC (or frequency if you got it) and spin the wheel. The voltage should be there no matter what speed. The frequency will increase with wheel speed.
post #24 of 24 Old 11-15-2013, 12:42 PM
EindhovenOne
2003 WJ
Question for you, MeanGreenZJ...
My question in totally unrelated to this topic, but I didn't know of any other way to ask you. A while back to posted about adding a Texas Crypto chip to one of those aftermarket flip-key remotes so one could avoid having to mount an actual key near the Sentry sensor in the steering column. I can find those chips readily available online but how would I go about programming it? Would I just tape it to a non-Sentry key that I got cut from my original keys and then go about programming it just like if it were an actual Sentry key with the chip embedded? Again, sorry to hijack this and go off-topic, but I was just curious. Thank you for your time and consideration.
-E
"Saepe Expertus, Semper Fidelis, Fratres Aeterni"
"Often Tested, Always Faithful, Brothers Forever"
EindhovenOne is offline
