About to install IRO longarms - Page 3 - JeepForum.com
post #31 of 84 Old 02-21-2014, 02:59 PM
skain8
skain8's Avatar
A transfer case drop is the equivalent of a dual steering stabilizer.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #32 of 84 Old 02-21-2014, 03:31 PM
Timbo24
What do you guys think. I have 4.5 inch long arm lift with a Jks track bar and slight bump steer. I have an rc track bar drop bracket and drop pitman in my garage. Should I install them and weld the bracket in? Sorry for the slight hijack
Timbo24 is offline
post #33 of 84 Old 02-21-2014, 05:08 PM Thread Starter
Jaketit
Originally Posted by brouwmat
Just removed my TC drop after having it on there for the past 9 months and didn't notice any difference at all. (4" lift) Sent from AutoGuide.com App
Well u think I (lost) the original bolts for the TC, so I guess I'm going to the dealership to replace those if I remove it. I'm just not sure how 6.5 inch springs will affect the geometry of everything.
Jaketit is offline
post #34 of 84 Old 02-21-2014, 07:31 PM
xJoshxx
2012 WK
like having a drop pitman with a adjustable Trackbar!
Better spray them IRO bolts with some Paint or they'll be corroded and rusty in no time. same thing if you bought the adjustable long arms
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #35 of 84 Old 02-22-2014, 01:27 PM Thread Starter
Jaketit
Managed to get the brackets semi mounted today. I still have to drill the holes and install the front bolts and nut plates but I'm kinda fighting a hangover from lastnight and it's a little toasty here today.
Jaketit is offline
post #36 of 84 Old 02-22-2014, 02:30 PM
xJoshxx
2012 WK
Originally Posted by Jaketit View Post
Attachment 1109657
Transfercase Drop get rid of it now!
2011 WK2 ORA2 sold
xJoshxx is offline
post #37 of 84 Old 02-22-2014, 04:06 PM Thread Starter
Jaketit
Indeed I will. I'm going get the holes drilled for the nut plates and get everything on and drive it around and see about vibes then put it back to stock. I gotta get the stock bolts again from the dealer.
Jaketit is offline
post #38 of 84 Old 02-23-2014, 05:28 PM Thread Starter
Jaketit
Any second opinions on removing the TC drop. Just to easy my mind before I do it??
Jaketit is offline
post #39 of 84 Old 02-23-2014, 05:41 PM
skain8
skain8's Avatar
Do it already. Really. If you get driveline vibrations from the front or rear or a combination of the two, properly fix it by adjusting the respective pinion angles. What the hell is the point of lifting your 6" only to have the ground clearance at the midsection of your WJ of that of a 4" lift?
skain8 is offline
post #40 of 84 Old 03-11-2014, 03:10 PM Thread Starter
Jaketit
Ok. A little update since I had a little time today to Putz around with the jeep. I finally removed the transfer case drop and put everything back to stock, like everyone has been telling me to. I also fished in the new bracket nut plates. Baby steps.
Jaketit is offline
post #41 of 84 Old 03-11-2014, 04:33 PM Thread Starter
Jaketit
Installed.
Cleaned up and painted.
And a shot of her last days on Rough Country on the fronts.
Jaketit is offline
post #42 of 84 Old 03-14-2014, 02:15 AM
nUcKiNfUtZ
2003 WJ
How did removing the TC drop effect the ride?
I'm starting to think my parents didn't buy me enough tonka trucks as a kid.
nUcKiNfUtZ is offline
post #43 of 84 Old 03-14-2014, 01:35 PM Thread Starter
Jaketit
. Well now I think my vibes went from front to back. At least that what it feels like. Upon deceleration at about 45 to 35ish in the rear. I guess my next step is a slip yolk eliminator. Never ends. I love it.
Jaketit is offline
post #44 of 84 Old 03-14-2014, 05:46 PM
nUcKiNfUtZ
2003 WJ
Are you using stock drive shafts?
post #45 of 84 Old 03-14-2014, 07:23 PM Thread Starter
Jaketit
Yes I am. I've been running them for about two years now lifted, with no problems.
Jaketit is offline
