About to change valve cover gasket, need your advice - JeepForum.com
post #1 of 11 Old 12-29-2011, 07:37 PM Thread Starter
lucer105
2002 GC Laredo sport, 4.0L I6
About to change valve cover gasket next week, I am going to get the fel-pro one. Several questions before I get started.
1. Do I need to disconnect anything? (battery? any other hose? wires?)
2. What kind of scrape I should use to remove the existing gasket? Plastic or Metal?
3. Do I need silicone all over the contact surface between the cover and the gasket?
4. Can I reuse cylinder head bolts?
5. Do I need to extremely careful when I tighten up the bolts, do they have to be exactly tightened to a specific degree?
Any suggestions? and experience?
Thanks~
And, at last, is this useful guide?
http://www.autozone.com/autozone/rep...96b43f802d824b
lucer105 is offline
post #2 of 11 Old 12-29-2011, 07:49 PM
jfazio5188
1. I usually always disconnect the neg battery cable for any job. Other then that you may need to move a few vacuum hoses and/or plugs. Just be sure to label everything so it goes back together easily.
2. You never really want to scrap a machined surface, but if its on there real good use plastic.
3. DEFINITELY use RTV if you are scraping the surface. Clean the surface on the head real good then spread it evenly with your finger around the head surface.
4. You shouldn't need to touch the head bolts...? The valve cover has its own bolts.
5. Yes you have to be careful when tightening the bolts. If you snap any of them your in for an annoying day. Torque them all down to 85 INCH pounds.
That guide is to remove a cylinder head. My answers are to change a valve cover gasket. Did you mean head gasket?
jfazio5188 is offline
post #3 of 11 Old 12-29-2011, 08:13 PM Thread Starter
lucer105
errr, meant to say valve cover bolts. Thanks
I need to tighten them up several times, right?
I did not pay attention.... and when I read that, I was thinking why a gasket is so complicated?....LOL
Thank you~
lucer105 is offline
post #4 of 11 Old 12-29-2011, 08:35 PM
98jgc
2005 WK
I was worried about disconnecting the cables that run across. I pinched the clips so that I could move them out and around somewhat but did not have to disconnect. If you do it that way tolerances are tight maneuvering the cover on / off but very doable. Resist the temptation to clean any sludge, because if disturbed it may get into the pan and clog the oil pump pick up. My head was very clean except for some sludge around piston #4. I hit it carefully with a few q tips. To get the back bolts you will be laying on top of the engine face down - at this point you will say damn I should have left it alone. Then again I am only 5' 8.
98jgc is offline
post #5 of 11 Old 12-29-2011, 08:44 PM
jfazio5188
Some people recommend tightening them to the torque specs, then backing them out half a turn, then torquing them again, but with the bolts only needing 85 inch pounds you shouldn't need to do that. I would get a torque wrench to make it a lot easier.
post #6 of 11 Old 12-29-2011, 09:26 PM
Cirruslydakota
Battery cables. Throttle, TV, and Cruise control too.
Unless someone used RTV you wont need any kind of scraper. Use a rag and paint thinner/brake clean and wipe down the gasket surface on the head. If you feel its not clean enough grab some scotch-brite to clean your surfaces.
No, unless either surface has been gouged by scraping you dont need to use any type of sealer. The fel-pro part is the mopar part (the're Mopars gasket supplier for OEM). When you pull it out of the box note the mopar P/N stamnped into the metal cross bar in the front. This faces up and forward.
Im assuming you mean the valve cover bolts so yes. You can reuse them. (for the future you shouldnt reuse the cylinder head bolts.)
Yes 85 in-lbs (INCHES!), if you dont have an inch pound torque wrench then go out and buy 1/4" one. Itll come in handy in many places where a 3/8 one is simply too big. If you can find a 1/4 drive it makes for a much easier time when it comes to torqueing the rear bolts. Youll also find a deep socket and 3" extension both in 1/4 drive handy here.
Torque from the center out in a criss-cross pattern or circular clockwise pattern keeping it even all the way out to the edges. I did mine in two stages first at 40, then up to 85. After a few heating/cooling cycles of the engine recheck your torque. While youre doing this job go ahead and replace the CCV valves and grommets. Trust me, do it now and you wont be doing this job again later. Also, on a piece of paper draw a crude diagram of the cover and mark where all the different bolts go along with which locations have studs and the location of the ground strap stud. Didnt draw one and you already took it all apart? No biggie, I have a crude diagram for reference. Message me if you need it. Heres a good write up with P/N for all the CCV parts. http://www.jeepforum.com/forum/f310/...ite-up-733669/
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #7 of 11 Old 12-29-2011, 10:13 PM Thread Starter
lucer105
OMG, it is really detailed! Thank you~
I will do that on Saturday, my mechanic said it will take me two days to do the clean, I really want to challenge that.
Thanks again!
lucer105 is offline
post #8 of 11 Old 12-29-2011, 10:24 PM
Cirruslydakota
I do what I can. Your mechanic is a sissy, of course having a wash tank at your disposal makes cleanup a snap.
Bear - 99 WJ Laredo
post #9 of 11 Old 12-29-2011, 10:27 PM
malibubts
I was going to post everything he said down to the CCV Valve replacement. So a big old x2!
Eric - '02 Laredo Grand Cherokee
malibubts is offline
post #10 of 11 Old 12-31-2011, 11:17 PM Thread Starter
lucer105
Okay, thank you again~ I changed both CCV valves and the valve cover gasket. The cover is pretty clean, to my surprise. But I do screwed up a little bit.....
I only screw the very inside bolt tight, but not specifically 85 inch pound, since the torque wrench is too big.....
I also broken the first bolt(count from the passenger location to the bumper, and left if you face the jeep).....
I am wondering will that be problematic? I will get a new bolt for that tomorrow....It was the first time using a torque wrench, not familiar with the click sound....
lucer105 is offline
post #11 of 11 Old 05-07-2013, 05:59 AM
MiniCwik
Rectifying an old post, there is a mentioned diagram of the valve cover bolts does this happen to include the location of the standard head bolts versus those with protruding threads on top?
I am putting a rebuilt 4.0 in and the shop that built it removed the valve cover before I could get a reference of where the bolts went.
Thank you
MiniCwik is offline
valve cover gasket MoparMan1990 WJ Grand Cherokee Forum 15 12-14-2013 07:16 PM
valve cover gasket torque specs mreed21 WJ Grand Cherokee Forum 5 09-25-2011 06:27 PM
Post Head Gasket Change Oil Flush Oil? mrJ WJ Grand Cherokee Forum 11 11-06-2010 12:21 PM
Valve cover gasket help PLEASE g-off70 WJ Grand Cherokee Forum 4 04-12-2010 12:42 PM
