AAAARRRH please help stuck jeep - JeepForum.com
post #1 of 16 Old 01-13-2014, 12:47 AM Thread Starter
wonkiestauto
Please help my jeep has now immobilized itself!!!!!!! Red alarm light on dash stayed on and no engine management light on dash lift also skis light out on dash can't believe this have just spent load of cash doing bits and pieces now this totally disheartening can any help?????
wonkiestauto is offline
post #2 of 16 Old 01-13-2014, 07:06 AM
ChrisHager
Administrator
ChrisHager's Avatar
Are you using the proper chipped/programmed key? What happened before it immobilized itself? It's hard to diagnose an issue if you don't give details about what the possible cause was.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #3 of 16 Old 01-13-2014, 07:26 AM
Jeeples
Jeeples's Avatar
Are the fuel and battery gauges responsive when you turn the key to the 'On/Run' position? The battery gauge should show around 12 volts and obviously the fuel gauge will show the current level of fuel in the tank.
If both gauges stay parked at the left side of their readings then chances are the ECM is dead. If both gauges function normally and the engine runs for a few seconds before shutting down then you may have a bad SKIM module.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #4 of 16 Old 01-13-2014, 08:56 AM Thread Starter
wonkiestauto
Right I'm having all sorts of weird things just happen gauges work then don't interior lights are random sidelights too also on dome the miles to empty rather than miles just has 3 dashs there is half a tank of fuel it is completely random it cranks over fine one thing the key symbol on dash also the engine fault lite when they don't light it has this problem when they come on normally and go out it starts fine even with alarm led lit ? HELP!! Please
post #5 of 16 Old 01-13-2014, 09:14 AM
WJChris
WJChris's Avatar
Insert most common suggestion here:
"Check and re-set your battery connections"
Also you may have a faulty Body Control Module.
WJChris is offline
post #6 of 16 Old 01-13-2014, 09:22 AM Thread Starter
wonkiestauto
Thanks have tried battery trick doesn't work cheers like I say random the other thing is drivers door doesn't lock or unlock with fob ? All other doors do and fob doesn't set alarm? Power button on drivers door works normally even when I turn key in drivers door lock it doesn't open others? Cheers guys for all help I do appreciate it
post #7 of 16 Old 01-13-2014, 09:31 AM
ChrisHager
Administrator
ChrisHager's Avatar
Check the wiring in the boot between the driver's door and the body...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #8 of 16 Old 01-13-2014, 10:29 AM Thread Starter
wonkiestauto
Have done the wiring when I got it have rechecked it all seems ok am at a loss at the mo I hate electrical gremlins there the worst!!!!!!
post #9 of 16 Old 01-13-2014, 10:34 AM Thread Starter
wonkiestauto
Oh forgot to say have got second hand bcm drivers door window switch and latch so will try them tmorrw
post #10 of 16 Old 01-13-2014, 02:48 PM Thread Starter
wonkiestauto
Does anyone know if I have to program a second hand body control module? Cheers
post #11 of 16 Old 01-14-2014, 05:07 PM Thread Starter
wonkiestauto
Right have just finished looking at Jeep and you would not believe what I found !!!!! Replaced bcm still the same so redid all earth points still the same checked dash still the same when I got Jeep it had an iPod adaptation on radio this had stopped working which I put down to intermittent fault I had so anyway popped radio out checked all connections all OK hmmmm I'll just disconnect iPod thingy blow me it all kicked back into life I thought W T F!!!!!!! Anyway it turns out it was iPod adaptor don't know how??? But fixed AT last cheers for everyones help now for roof lights any ides or pics anyone
post #12 of 16 Old 01-14-2014, 05:28 PM
berndog67
2003 WJ
dam thats a new one, gotta love how picky our jeeps are! were u playing pirate'd music, lol!
2003 WJ Overland, 4.7HO, D30 & D44A (1 tons going in now!), RC Long Arm, lifted 4" Front 6" Rear, RC 2.2 4" Shocks, JKS track bar, custom hi-steer, 35" Procomp M/T's on JK rims, beefed up Overland rock rails, custom skids and dif gaurds, Rugged Ridge 8500 synthetic winch in custom hidden mount
berndog67 is offline
post #13 of 16 Old 01-14-2014, 06:19 PM
EightEleven
But were you able to cause the fault again? I say plug it back in and see what happens and that it wasn't just a coincidence!
EightEleven is offline
post #14 of 16 Old 01-15-2014, 01:34 AM Thread Starter
wonkiestauto
Yes plugged back in heard a clicking then jeep stalled so quickly pulled plug back out jus in case it was shorting something out oh an yes may have been the music found out the missus had put the cheeky girls on ipod lol cheers guys on a different note can anyone recommend a roof basket I want something I can put lights on cheers
post #15 of 16 Old 01-21-2014, 01:19 PM
berndog67
2003 WJ
weird one, but least you know now, ROLA racks seem to be popular, look great on wj's and not too expense either, alot of guys find good deals on them off craigslist, been looking for one for myself for awhile now with no luck yet, plus with the rola racks u can get extensions to make them longer and are fairly strong, so u can weld on any tabs u want, for a better mounting system or even spares and lights
