A1Cardone power steering wj grand cherokee - JeepForum.com
post #1 of 10 Old 02-05-2014, 03:13 AM Thread Starter
AliAbed
Wj A1Cardone power steering wj grand cherokee
Hi the A1Cardone pump are good for wj grand Cherokee with the hydraulic fan http://www.partsgeek.com/mmparts/pow..._cherokee.html
AliAbed is offline
post #2 of 10 Old 02-05-2014, 04:41 AM
99SK04GTX
I recently installed one on my 2004 V8. Best to get with the reservoir and note there are different pumps for the V8 and the I6. You will need a PS pump pulley puller to remove AND install the pulley on the new pump. A new pulley is only $12, mine broke (it is plastic w/ metal insert). Price Advance auto locally by going to retailmenot.com and getting a coupon code for 30% - 40% off; order online and pick-up locally.
99SK04GTX is offline
post #3 of 10 Old 02-05-2014, 05:13 AM Thread Starter
AliAbed
thanks my friend does your engine overheat with hard steering when your pump died
AliAbed is offline
post #4 of 10 Old 02-05-2014, 05:48 AM
99SK04GTX
No, mine was leaking
post #5 of 10 Old 02-07-2014, 09:03 PM
86cj74.2L
86cj74.2L's Avatar
I had hard steering at idle. But didn't have overheating issue.
I put a mopar reman on. Which came without the tank. Fixed the hard steering.
86cj74.2L is online now
post #6 of 10 Old 02-07-2014, 11:58 PM
MEinSoCal
that's exactly what i have too! i just bought the Duralast power steering pump w/ reservoir from Autozone which inclludes a lifetime warranty just in case. i hope to get it installed this weekend.
MEinSoCal is offline
post #7 of 10 Old 02-08-2014, 01:08 AM
Ah673000
Ali.... The reason your engine over heated ( I assume you have the 4.7 V8 ) is because the power steering pump drives the cooling fan.
Ah673000 is offline
post #8 of 10 Old 02-11-2014, 06:40 PM
scottieboy1707
Hi, so I just got a 2002 wj and when not moving the power steering seems to hesitate for a few seconds but then kick back on, but only when turning to the left. It doesn't seem to happen when moving or while turning right. Any opinions?
scottieboy1707 is offline
post #9 of 10 Old 02-16-2014, 08:50 PM
stangetr
I have no power steering at idle- 02 wj 4.7- the hyd fan barely moves, as soon as I hit the gas everything works, everyone said pump - I changed the pump- problem remains, still looking for a good answer
stangetr is offline
post #10 of 10 Old 02-16-2014, 10:40 PM
86cj74.2L
86cj74.2L's Avatar
I had good fan and zero cooling problems so I thought the steering box was leaking internally. Replaced it and still had hard steering at idle.
Bought a reman pump from mopar and it fixed it.
The fan will move slow. It only speeds up for certain things. If your concerned the fan isn't operating just pull the engine coolant connector with engine running. It should turn into a airplane.
Also if you got a pump from someone other than mopar it could still be the pump.
