99 wj that hesitates while accelerating. - JeepForum.com
post #1 of 8 Old 06-17-2010, 02:00 PM Thread Starter
ljhopp
I have a 99 wj that when I accelerate quickly the wj will studder or hesitate at 3000 rpm's then takes off again.
There are no check engine lights on. Just recentely I had a code p1391 came on and the engine had the same problem. I replaced the ckp and the hesiation went away but the sensor went out again, so I got a mopar ckp to replace the advance auto parts store one. The check engine light went off but the hesistion has stayed. This also a reman engine.
I am wondering what could the problem be? Could the tps be causing this. Also if i accelerate normal the engine will not hesiatate.
ljhopp is offline
post #2 of 8 Old 06-17-2010, 07:38 PM Thread Starter
ljhopp
Does anybody have an idea of what could be causing this? I think it's the tps going out.
ljhopp is offline
post #3 of 8 Old 06-17-2010, 07:43 PM
ZeeJay1997
The TPS can be tested with a digital voltmeter.
The center terminal of the TPS is the output terminal.
With the ignition key in the ON position, check the
TPS output voltage at the center terminal wire of the
connector. Check this at idle (throttle plate closed)
and at wide open throttle (WOT). At idle, TPS output
voltage should be greater than .350 millivolts and
less than 900 millivolts. At wide open throttle, TPS
output voltage must be less than 4.5 volts. The output
voltage should increase gradually as the throttle
plate is slowly opened from idle to WOT.
ZeeJay1997 is offline
post #4 of 8 Old 06-17-2010, 09:23 PM Thread Starter
ljhopp
I will try that tom. Thanks
ljhopp is offline
post #5 of 8 Old 06-18-2010, 05:29 PM Thread Starter
ljhopp
I checked the mv volts on the middle terminal and the volts fluctated all over the place. from .000 to 1.0 at idle. Could a bad tps also trigger a p 1391 because the engine light just came on and I replace my ckp with a mopar one.
ljhopp is offline
post #6 of 8 Old 06-19-2010, 08:35 PM Thread Starter
ljhopp
I replaced the tsp and the hesiatation got worse. So I think I am gonna get a camshaft position sensor and try that.
I replaced the cam sensor and it did not fix the problem.
ljhopp is offline
post #7 of 8 Old 06-21-2010, 05:37 PM
Dr-Detjen
I Have a 2000 limited 4.7 and it was doing the same thing, doggy in the low RPM's then 3000+ Bam power band. Had been that way for about 3-4 months... then It started stalling ramdomly, no codes. finally replace both Crank position sensor and Camshaft position sensor (as I read on jf.com) and getting the p1391 code. Had my PCM tested and failed on multiple sensors including on the Throttle position sensor. Replacing my PCM TODAY! I'll report back.
Dr-Detjen is offline
post #8 of 8 Old 06-21-2010, 09:13 PM Thread Starter
ljhopp
Originally Posted by Dr-Detjen View Post
I Have a 2000 limited 4.7 and it was doing the same thing, doggy in the low RPM's then 3000+ Bam power band. Had been that way for about 3-4 months... then It started stalling ramdomly, no codes. finally replace both Crank position sensor and Camshaft position sensor (as I read on gf.com) and getting the p1391 code. Had my PCM tested and failed on multiple sensors including on the Throttle position sensor. Replacing my PCM TODAY! I'll report back.
Thanks, I think I have a bad pcm also.
ljhopp is offline
Hesitates to shift when cold subliminal ZJ Grand Cherokee Forum 10 03-20-2016 11:24 AM
1998 Hesitates, chugs... rdupuis ZJ Grand Cherokee Forum 19 06-20-2011 12:11 PM
ZJ 5.2L hesitates when cold? tomk864 ZJ Grand Cherokee Forum 5 03-11-2009 10:09 PM
Hesitates on highway BDC ZJ Grand Cherokee Forum 2 12-08-2004 12:24 PM
5.2 Hesitates..... 97grand ZJ Grand Cherokee Forum 5 09-21-2004 10:53 AM
