99 WJ Fuel leak and Evap leak - JeepForum.com
post #1 of 1 Old 06-21-2013, 10:18 AM Thread Starter
orestes107
Wj 99 WJ Fuel leak and Evap leak
’99 JGC 4.0L
I have been racking my brain and searching the forums but need some advice.
So filled up my tank the other day until the pump shut off. Went inside the gas station and when I came out there was a small puddle of gas which was dripping slowly from the middle of the skid plate. Felt around the filler neck and hoses but could not feel anything wet and could not see where it was coming from exactly.
Then I drove to my buddy’s house about 20 miles away. Parked it and noticed it was constantly dripping. After about 15-20 min, still dripping. Took the gas cap off and the dripping slowed to a stop.
I know that I have to drop the tank to figure out the leak which seems like it would either be the rollover valve or pump seal. I just want to make sure I’m not overlooking something because I have already dropped the tank twice in a couple months. Once to replace the skid plate, fuel pump, send and return lines from pump and the filter/pressure regulator. Second time was to tighten some connections after the fuel pressure line came off the pump while driving (not fun).
I attributed the loose clamps to trying to do too much in one day and possibly the new line shrinking slightly (I read that can happen right?).
But this also happened right after I replaced the gas cap trying to get rid of a P0455 gross evap leak.
Could the gas cap be part of the problem? Maybe doesn’t allow enough air in creating too much pressure on the system?
After taking off the cap I put the old one on and have got the tank near empty without seeing any leaks (but the CEL came back on).
Where do you think the most likely place for a leak would be?
Is there a way to test after dropping the tank?
Do you think the evap leak is gas cap related or leak related?
Any help would be greatly appreciated because I really want to take care of it this weekend and not have to worry about getting stranded again.
orestes107 is offline
