99 WJ With front wheel vibration at 50mph no more ideas - JeepForum.com
post #1 of 6 Old 09-01-2011, 12:08 PM Thread Starter
99GC4point7
I just bought my first jeep Its a 99 GC Laredo With the 4.7 quadra trac i had noticed that the front axel cv joints were bad so i replaced the two front axels both wheel bearings my self to all torque specs and had the front wheels balanced and switched sides at farm and fleet while also having them check the front end for any looseness tie rod ends ect and they found it all to be tight. Right now i currently have the front drive shaft off to help weed out the problem. The Front brakes are in good condition with a lot of life left. But when i am going down the road at 47-50 mph it will shake real bad every other speed i can hardly notice it except for when its shaking and i start to apply the brakes it gets ten times worse and almost shakes me off the freakin road i say WTF and i have run out of ideas what should i check and any ideas you have would greatly help me. Thanks Again
99GC4point7 is offline
post #2 of 6 Old 09-01-2011, 07:12 PM Thread Starter
99GC4point7
Ok so I replaced the front brake pads and rotors still no help I switched the front tires for the rear and found that I have a bad tire go figure but at least I now have life time warranty on all the parts I repaced
post #3 of 6 Old 09-01-2011, 07:14 PM
MoparMan1990
1992 XJ Cherokee
i hate the same exact problem but once i replaced the rotors n cv's it went by by..
MoparMan1990 is offline
post #4 of 6 Old 09-01-2011, 07:15 PM
MoparMan1990
1992 XJ Cherokee
i had *
post #5 of 6 Old 03-05-2013, 02:52 AM
jeffnoumea
HELLO
Could you explain ....
You said " i hate the same exact problem but once i replaced the rotors n cv's it went by by.. "
What is the rotors n cv's.....
Thanks
Jeff
jeffnoumea is offline
post #6 of 6 Old 03-06-2013, 11:45 AM Thread Starter
99GC4point7
The front Axel shafts have cv joints that go bad and the rotors are part of the brakes that the brake pads squeeze to stop they can warp if they get hot or crack
steering wheel vibration around 45.... spanky02 WJ Grand Cherokee Forum 7 07-28-2011 11:37 PM
Alright everyone, I have a vibration and can't find it...any ideas? top1000nole WJ Grand Cherokee Forum 4 05-03-2011 10:28 AM
4 wheel drive vibration? CMac019 WJ Grand Cherokee Forum 4 01-10-2011 09:03 PM
Steering Wheel Vibration Queston lilZeus WJ Grand Cherokee Forum 18 11-02-2010 07:01 PM
Front End Vibration - ??? filipm WJ Grand Cherokee Forum 6 03-25-2010 01:43 PM
