99 WJ bump steer - JeepForum.com
post #1 of 2 Old 01-26-2011, 07:57 PM Thread Starter
ledfoot02
2000 ZJ
Wj 99 WJ bump steer
1999 grand cherokee 4.0L just installed rough country 4 inch lift with the adjustable track bar and had it alinged i got the lower control arms at 16inch center to center as per the instruction now I got bump steer the leads into DW , so tonight i adjuster the control arms thinking it was a caster problem but that wasn't it but now when i hit the brakes the jeep pulls to the right so i took it back to my shop and checked of anything loose nothing. I used a magnet angle finder to get the right degrees on the front rear but that didn't help so I put it back to 0 degrees. My question is why does it pull to the right and it never did before i screwed with the control arms.
Thanks
Eddie
Shop Manager
Bovanis Towing and Service Center
Your Dodge and Jeep Specialist
Eddie (KB3NUN)
ledfoot02 is offline
post #2 of 2 Old 01-26-2011, 10:16 PM
sinbad85
Could be one LCA is longer than another, making it track to one side. Its hard to measure 16in on those arms because they have they bend in them. If you jeep is on level ground put your angle finder on the bottom of the ball joint and you should be around 5deg. Both side should be as close as possible. Also make sure your track bar is adjusted right.
2001 WJ 4.7L-selec-trac/4.5" Teraflex springs\IRO Long arms\Iro adj rear LCA/Bilstien 5100 series shocks/ IRO steering Equalizer/|265/75/16 Goodyear Dura-Tracs on Stock rims\Rear Tube Bumper with carrier|sliders|mopar skids.
sinbad85 is offline
bump stops gc3381 WJ Grand Cherokee Forum 4 12-20-2010 12:05 PM
still have a little bump steer travisbanshee67 WJ Grand Cherokee Forum 5 12-17-2010 07:19 AM
CLUNK n bump on the Highway torx WJ Grand Cherokee Forum 14 11-01-2010 04:07 PM
WJ bump in 1st and 2nd Gear RootJ WJ Grand Cherokee Forum 4 07-18-2010 07:20 PM
Come to a stop...then a bump feel? summett WJ Grand Cherokee Forum 4 05-27-2003 07:19 PM
