99 WJ 4.0L engine swap help - JeepForum.com
post #1 of 28 Old 02-02-2010, 09:04 AM Thread Starter
thaBrad
So the shop just called me and said the knocking noise is your rod bearings. He offered a quote of $3K for a reman engine with a 3year/120K warranty!! Yea, I don't have that money, so I called my buddy who owns a parts store and he was busy but said he could get one alot cheaper and either I swap it or find a buddy (which I could). BTW...engine has 150K miles on it.
Should I look into the wrecked Jeeps for that engine with unknown problems it may have? And I know there are tons of 4.0L, I'm a middle of the road mechanically inclined guy. I don't have special tools but can understand what I'm doing to put it back the same. But with my 4.0L, I'm gonna try to stay in my year range, cause I read an article in 4Wheeler about these engines and how they have different external mounting points for your accessories (pumps, etc) So what year range should I stay in of what models maybe?
Never swapped before, but if I get lucky and find the same engine, is it just a disconnecting of the exhaust, engine mounts, wires, tranny basically and putting the new one in putting those back on? Turn the key?
Thanks for the help
3" IRO, Bilstein's, 32" KM's on 17" Soft 8's
thaBrad is offline
post #2 of 28 Old 02-02-2010, 09:13 AM
Wilky93
Can you have the car off the road for an extended period of time? If so, why not just rebuild? that would be your cheapest option and a great time to put some hotrod stuff in it.
Wilky93 is offline
post #3 of 28 Old 02-02-2010, 10:09 AM
jtsjeep99
I agree. Rebuild if you can. That way you've got the same engine and know everything will work the same. You might even have it stroked.
jtsjeep99 is offline
post #4 of 28 Old 02-02-2010, 10:25 AM Thread Starter
thaBrad
Yes I have another vehicle I just got out of the shop too, it had a broken timing belt tensioner spring. $500 UGH! Keeps coming.
So to do a rebuild, I always wanted to stroke or at least do small upgrades. I just need some kind of picture showing the engine in its pieces. To understand completely what I have ahead. So to start off, I should start taking the bumper off, then to the components, etc? As I'm saving the money. But I called my brother who has a buddy with a auto parts store and he said the WJ's are more expensive to find used engines...about $1200-1400. Jaspers are $1600. But a rebuild would be half probably right? And then what kind of "special" tools would be needed to do the rebuild?
thaBrad is offline
post #5 of 28 Old 02-02-2010, 10:33 AM Thread Starter
thaBrad
And do I have a short block or long block?
thaBrad is offline
post #6 of 28 Old 02-02-2010, 11:16 PM
Wilky93
short block and long block refer to if the motor has a head on it or not basicly.
as for special tools, it depends if you want to get into the head too. if not I thing mostly you only need a piston right tool ( so you can get the pistons into the bore some feeler gauges and a short piece of 2x4. buy a hanes for it. they go thru a rebuild in that. I know you have to know someone that has rebuilt a motor or two so get some help.
But that being said, it's a machine. there for if you can turn a bolt the right way and watch how it comes apart, you can figure it out.
Oh and a bearing going bad is not the end of the world for a motor. it just needs repair. I may actually be as easy as Dropping new bearings in and nothing more....it could be.
Wilky93 is offline
post #7 of 28 Old 02-03-2010, 04:54 AM
Hexonut
it could be as easy as swapping out that oil pump too, sounding all like a coffee can full of rocks, I would not attempt a rebuild myself or alone if I did not know the difference between a short and long block but we gotta learn somehow.
It's complicated dude and there are a million little tricks and methods that you only acquire after year and years of busting your knuckles rebuilding engines...
look into a short-block then you and a friend can do the swap over of the head and accessories for a conditioned learning experience, Jasper will also rebuild your same engine if you desire to keep it matching numbers (which will really never matter on a ZJ/WJ)
matching numbers means the serial number to the motor matches the frame it was installed in at the factory, it does not have anything to do with the internals of the engine...
Hexonut is offline
post #8 of 28 Old 02-03-2010, 09:03 AM
Wilky93
http://www.quadratec.com/advisor/jee...cyl_engine.php
Here is an exploded view of a 4.0, You will need help from someone that's rebuilt an engine before but, you have to have some buddy somewhere that know what he's doing. If you we're not so far away I'd come help youbut yeah, it's a full work day just driving to you.
Wilky93 is offline
post #9 of 28 Old 02-03-2010, 09:08 AM
JrMechanic
If your engine wasn't smoking or producing excessive blow by, you can just replace the rod and main bearings. You can even do this with the engine in the Jeep.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #10 of 28 Old 02-08-2010, 07:17 AM Thread Starter
thaBrad
I can do this, its just deciding which plan of attack. I didn't have any smoke or blowby so I'm sure its just the bearings and nothing to the crank or cylinder walls. A buddy said we could pull the rod bearing out the bottom (engine still in) and replace them, but its just a band-aid. Engines online from yards are still too high for me. Nothing under $1,000 worth crap. So a fix instead of swap is my route I guess. Like I said, I'm a medium grade mechanic, just never pulled an engine before.
I have plenty of friends and a brother with the experience, just like to know as much as possible before going in. I appreciate ya'lls input.
Wilky....thanks!
thaBrad is offline
post #11 of 28 Old 02-08-2010, 08:41 AM
Wilky93
that's the attitude you can do it. And it's not just a band-aid. Inspect the Crank journal and the caps for damage and if they're fine then there's nothing to worry about. Replace the Oil pump while your in there just for added Insurance, maybe the rear main seal if it looks to need it. if you really want to do a swap check Craigs list for a Motor. there are 2 dozen of them here for 300-400 bux that could be prime stroker motors.
4.0 with 88k in Indy for $500
4.0 for $350 unknown mileage
Get some beer, and some buddys and fix her up
Wilky93 is offline
post #12 of 28 Old 02-08-2010, 08:59 AM Thread Starter
thaBrad
Well Wilky thats my problem...of course I have to have the "Jeep" that can't swap from other models! I have to have a WJ engine. Done some research and been told by mechanics that I have to swap a 99-04 WJ 4.0L. Something about them having different mountings.
thaBrad is offline
post #13 of 28 Old 02-08-2010, 09:16 AM
JrMechanic
You can use a 4.0 out of a TJ as well. I believe you can also use an earlier 4.0, you just have to do some modifications (use your head, intake, mounts, get rid of the oil filter adapter, make a mount for the coil pack, etc.)
Just replace the bearings though. As wilky said, this isn't a band aid. Why replace what you know to be a good running engine with one you know nothing about? Go get a gasket set, oil pump, and rod bearings. Droop the front axle down, drop the oil pan, and replace the bearings.
post #14 of 28 Old 02-08-2010, 09:19 AM
Wilky93
Yeah as far as i know the Blocks are all the same, someone correct me if I'm wrong, so you'll just have to do some parts swapping from one to the other.
Wilky93 is offline
post #15 of 28 Old 02-08-2010, 09:26 AM Thread Starter
thaBrad
Really?!! Ok then, I'll start doing some research then! Cooooooool!!! I've seen a few earlier ZJ engines for sale on Craigslist from WJ owners cause they said they thought it would work. But it didn't so they were selling them.
So I just have to do some mods, which is no prob really. I work at a metal shop with all the tools and material I would need. Hmmmmm, interesting! Thanks guys...really!
thaBrad is offline
Engine swap. '99 5.9 into a '98 Wreckless_71 ZJ Grand Cherokee Forum 3 10-07-2009 05:27 PM
Engine will not seperate from tranny?!? Engine swap 95cherokee33s ZJ Grand Cherokee Forum 2 05-05-2008 09:03 PM
engine swap smokestack ZJ Grand Cherokee Forum 20 12-25-2006 06:01 PM
engine SWAP!! joeyschribar ZJ Grand Cherokee Forum 12 08-20-2006 11:15 AM
V8 engine swap with AX-15 93DDQZJ ZJ Grand Cherokee Forum 5 11-19-2005 08:26 AM
