99 4.7l 242 - AWD selection = no movement - JeepForum.com
post #1 of 12 Old 05-23-2012, 03:47 PM Thread Starter
ZeJokee
Wj 99 4.7l 242 - AWD selection = no movement
I swapped in a 242WJ from a 01 i6 a few months ago. Everything went smoothly other than a vibration, mostly due to the case being long and drive shaft angle. Lately the vibration has increased and I am getting slight whine under 35 mph. Not very loud and all the time the vehicle is rolling, under power or not. My front drive shaft is pulled waiting to put in a new one. Today I decided to put it into awd to see if the whine is still there. Only issue is the Jeep would not move. Felt like the t-case was in neutral. If my understanding is right, it should send power to the rear wheels until they loose traction then send power to the front as well. I even put it into neutral to make sure I was actually in awd. When it is N I can hear a clanking ratching sound briefly if I rev my jeep. I replaced the shift forks and chain when I swapped it in. Everything else looked if perfect order. Fluid is full and still bright red. Am I just missing something or is the awd selection messed up in the case? If so I guess this could be the culprit of my vibration and whine.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #2 of 12 Old 05-23-2012, 06:48 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Your understanding is wrong. Both outputs receive power through an open differential planetary gear set. If even one tire is completely without traction (in the air for example) you won't move as all power is sent to that tire. With no front drive shaft, all power is going to that output.
ratmonkey is offline
post #3 of 12 Old 05-23-2012, 06:55 PM Thread Starter
ZeJokee
That's what I wasn't sure about. I knew it didn't function the same as the 247 but wasn't sure exactly how it distributes power. Thanks
ZeJokee is offline
post #4 of 12 Old 05-23-2012, 07:37 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
If you want to drive it without the front shaft, put it in 4pt.
~James
ezflip is offline
post #5 of 12 Old 05-23-2012, 07:41 PM Thread Starter
ZeJokee
I have 2wd for that. I was just testing the t-case because I thought it functioned more like the 247. Trying to figure out if the whine is coming from the t-case or something else. Already ruled out front pinion and transmission runs fine.
ZeJokee is offline
post #6 of 12 Old 05-23-2012, 07:43 PM
lestatsghost
X2 on that. In 4ft it is an open differential free to send power where it needs. 4pt modes lock in the drive shafts so equal power front and rear no matter if the front axle is off the ground or no drive shaft.
2004 Jeep Grand Cherokee Special Edition V8 - 4.5" Clayton Springs, RE Front 3175's, Zone Swaybar links, KOR A-Arm Spacer, Rancho RS5000 Shocks RS5239 Front RS5010 Rear, Unique "Soft 8" 15" Wheels 31x10.5R15 BFG's, ARB Bull Bar, Superwinch LP 8500 and a few other mods.
lestatsghost is offline
post #7 of 12 Old 05-23-2012, 07:43 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Oh yeah, for some reason I thought you had the rear shaft removed
~James
ezflip is offline
post #8 of 12 Old 05-23-2012, 07:44 PM Thread Starter
ZeJokee
Haha. Simple mistake.
ZeJokee is offline
post #9 of 12 Old 05-23-2012, 07:44 PM
narnwv
narnwv's Avatar
this would be accurate if he wanted to drive without the rear shaft.
~Aaron
narnwv is offline
post #10 of 12 Old 05-23-2012, 10:31 PM
Sohcvtec1995
Well to actually try to answer your question, did you adjust the cable correctly?
Sohcvtec1995 is offline
post #11 of 12 Old 05-24-2012, 04:19 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Huh?
His question was answered, the case is working correctly given the conditions it was subject to.
post #12 of 12 Old 05-24-2012, 06:14 AM Thread Starter
ZeJokee
The shift cable on the t-case? Yes, cable is set to the bottom hole on the mount and is adjust. It shifts fine into all selections and every selection works. I was wrong in my understanding of how the 242 awd works compared to the 247 but that has been cleared up.
ZeJokee is offline
242 , 4.7l , t-case , vibration , whine
Power Seat Motor Functioning, But No Movement Hazed_blue WJ Grand Cherokee Forum 10 10-21-2012 08:42 AM
Movement of Tie Rod and Drag Link OTownDaddy WJ Grand Cherokee Forum 28 04-02-2012 02:04 AM
is this normal movement for steering linkage(video) gdp WJ Grand Cherokee Forum 3 03-13-2011 05:20 PM
Rear shock movement longshot2134 WJ Grand Cherokee Forum 7 03-07-2011 06:10 AM
Jeep Radio Selection kopite77 WJ Grand Cherokee Forum 5 09-05-2010 03:02 AM
