8" inch lift? - JeepForum.com
 3Likes
  • 1 Post By GhostJeepWJ
  • 1 Post By xcaliber81
  • 1 Post By Topher11
post #1 of 6 Old 09-21-2017, 12:33 AM Thread Starter
halofreaks
8" inch lift?
I see a few 2"-ers, more 4"-ers and a lot of 6" lifts...
Has anyone gone the route of an 8 inch lift? Like has anyine dine a 6 inch lift and the used spacers in the springs to get an extra 2 more out of them?
Just curious...
We are everywhere.
We are the Three Percent.
halofreaks is offline
post #2 of 6 Old 09-21-2017, 03:39 AM
GhostJeepWJ
GhostJeepWJ's Avatar
IMO its too high for a WJ. Plus it's like opening Pandora's Box and a daunting task! Not only the expense of a really good lift kit (upwards to $3000) plus you would have driveline problems so both axles would need to be replaced w/custom lengths. It would also not look right unless you have 35"+ tires on it (37s really or 40's) that would mean new axles. Would definitely have to atleast do the front with a Rubi 44, and to be done right prob a D60 rear. You would also have to regear both axles. Plus, also tweak/strengthen the steering system.
Can it be done...sure. But just cause you can do something doesn't mean you should.....lol
Probably looking at $8-10k to be done right. And if it's worth doing, it's worth doing right.
Just my 2 cents....lol
RoysJeep likes this.
If you want to achieve greatness, stop asking for permission!!
2002 Grand Cherokee Overland 4.7 HO
2" IRO Spring Lift w/Bilstein 5100s 245/75/R17 Goodyear Armour Shield
GhostJeepWJ is online now
post #3 of 6 Old 09-21-2017, 05:44 AM
xcaliber81
It would look great though lol
GhostJeepWJ likes this.
xcaliber81 is online now
post #4 of 6 Old 09-21-2017, 06:07 AM
Topher11
Topher11's Avatar
most on 8" are on tons and at least 37". plenty of builds like that out there.
Jeeples likes this.
1999 WJ 4.0/6"/CLAs/33s/242SYE/ZJ Rad Swap
2006 LJ 4.0/2.5"/33s
Respected Access Is Open Access. Tread Lightly.
Topher11 is offline
post #5 of 6 Old 09-21-2017, 09:10 AM
PLAN D
I would use Clayton's 8" coils instead of 2" spacers
PLAN D is offline
post #6 of 6 Old 09-21-2017, 10:02 AM
Topher11
Topher11's Avatar
Clayton does not make a wj 8" coil.
Topher11 is offline
