7 codes on abs - JeepForum.com
post #1 of 6 Old 06-30-2013, 11:57 AM Thread Starter
toates89
1989 XJ Cherokee
7 codes on abs
I had my engine replaced about 6 months ago. about two weeks after the abs light came on.
I just recently jacked it up onto all four and tester the speedo on each speed sensor and replaced the front right sensor.
light didnt go off.
had the codes pulled and here they are.
abs 28
right front speed
left rear speed
right read speed
hydraulic pump circuit
abs power feed
and bus comm failure.
Any ideas?
side note i pulled the fuse panel under the hood and there was no fuse in the spot so i replaced it. didnt affect the light.
inspection is up tmrw.
toates89 is offline
post #2 of 6 Old 06-30-2013, 12:06 PM
doityourselfMM
doityourselfMM's Avatar
Looks like 'global' ABS terror! Is the large connector seated and locked onto the CAB (Controller-Antilock-Brakes)?
Was a DRBII used to pull the codes, or a DRBIII?
doityourselfMM is offline
post #3 of 6 Old 06-30-2013, 07:17 PM Thread Starter
toates89
1989 XJ Cherokee
not sure advance pulled the codes
toates89 is offline
post #4 of 6 Old 07-01-2013, 09:29 AM
pinky2252s
Then they most likely were not read with a DRB3 scan tool. It needs to be read with a DRB3 to get the proper codes.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #5 of 6 Old 07-01-2013, 12:16 PM
rdkendrick
2003 WJ
Most likely an OBDII reader. That's what these places use and mostly to get CEL codes.
Sent from my iPad using Forum Runner
rdkendrick is offline
post #6 of 6 Old 07-18-2013, 09:12 AM Thread Starter
toates89
1989 XJ Cherokee
After 100 or so miles my light went off. i guess the sensor did the trick.
toates89 is offline
