545RFE - Anyone know how to shut 5th gear for towing?? - Page 2 - JeepForum.com
post #16 of 22 Old 12-20-2011, 07:39 AM
04ovrland
he wasnt asking HOW to run off OD. he knows he can hit the button to shut OD off.
What he is asking is how to only shut 5th gear off, because 4th and 5th are shut off when you use the o/d button to shut od off.
As far as the OP asking how to shut only 5th gear off, i don't think its possible mainly because jeep did not design the tranny to work that way, About the only way to make it work like that is to drive 65 instead of 75 on the highway. this will gain you MPG and reduce wear and tear, although it might add an hour or so to the trip difference depending on the length of the ride. 63 is the sweet spot for my jeep, i can get into the 24mpg range on the highway( of course thats not towing)
2004 Overland WJ 4.7ho/545rfe/247/d44a
04ovrland is offline
post #17 of 22 Old 12-20-2011, 01:38 PM
jimrowe0
2005 WK
I always tow my boat with OD off, unless on long highway stretches.
jimrowe0 is offline
post #18 of 22 Old 12-20-2011, 06:29 PM
99TJSahara
Originally Posted by MiCrOz View Post
As far as I've ever seen, there is no choice to be able to select 4th gear with the 545. If it is possible to flash to 45RFE software, you'll lose the 5th gear, but Im not sure if its even possible to downgrade.
On my 06 dodge ram 1500 HEMI, 545fre, there was tow/haul mode which lokced out 5th, and OD off which locked out 4th and 5th.
I've been trying to find a way to do this to our WJ, without pissing off the computer.
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #19 of 22 Old 12-20-2011, 06:50 PM
Rocklobster
Thaught there was something about that on wj jeeps IDK
Sent directly from my brain using JeepForum
Rocklobster is offline
post #20 of 22 Old 12-20-2011, 07:43 PM
jeepvsgti
Originally Posted by ZAM View Post
Are you supossed to use OD while towing? I tow my boat on average 3 times a week (2500lbs) and I don't do anything differently, just put it in drive. I've been doing it for years with no problem. it may be the wrong way though, Im not sure
depends on the size of boat. if your transmission is constantly shifting in and out of the higher gears, i would click off the o/d. but if its shifting pretty normally, than your good.
current: 1999 WJ limited quadradrive
RIP: 1982 CJ7 limited, 1986 2 door 2.8l XJ, 1991 XJ ltd, 2001 XJ, 1998 XJ, 1962 willies wagon
jeepvsgti is offline
post #21 of 22 Old 12-20-2011, 07:52 PM
MiCrOz
The only way I see that possible is swapping the TCM's
MiCrOz is offline
post #22 of 22 Old 12-20-2011, 08:00 PM
little_Jeep
I use my 2000 WJ to tow 5k or a little more on a regular basis.. I always use button and lock OD off.. I figure fuel is cheaper than a transmission rebuild.
little_Jeep is offline
545rfe slow to engage drive gear. Solenoid Pack? lumpster WJ Grand Cherokee Forum 25 01-06-2017 10:29 PM
545rfe gasket spiro WJ Grand Cherokee Forum 7 12-29-2013 11:46 AM
WJ - 545rfe won't go into reverse. MrBaz WJ Grand Cherokee Forum 6 08-19-2011 08:56 AM
4.7 w/ 545rfe guys come in here! WJeep47 WJ Grand Cherokee Forum 11 08-04-2011 08:06 PM
new transmission pan 545rfe? mcclintock89 WJ Grand Cherokee Forum 0 09-10-2010 02:19 PM
