545RFE - Anyone know how to shut 5th gear for towing?? - JeepForum.com
post #1 of 22 Old 12-17-2011, 03:15 PM Thread Starter
Jet 4.7
Wj 545RFE - Anyone know how to shut 5th gear for towing??
Hi Guys, I've got a bit of long distance towing to do in my 2001 4.7 w/ 545RFE gearbox, has anyone out there been able to lock out 5th and keep 4th. I'm towing 3500 - 4000lb camper and hauling in OD on and OD off modes is painful on a long trip at 55-60 mph!
Any ideas appreciated!
Jet
Jet 4.7 is offline
post #2 of 22 Old 12-17-2011, 03:19 PM
Rocklobster
I believe od off is what you need to be using, I think that is does not only shut off od but changes the shift points to give you a little more power.
Sent directly from my brain using JeepForum
Rocklobster is offline
post #3 of 22 Old 12-17-2011, 03:35 PM Thread Starter
Jet 4.7
Hey RL, thanks for the reply, agreed - but towing with OD off (3rd gear) has the rpm at about 2600 and is heavy on fuel, where as with OD on (5th gear) fuel econ is ok but no torque because of the 1600 rpm or so. 4th gear would be ideal if i could just select it!!!
Jet 4.7 is offline
post #4 of 22 Old 12-17-2011, 03:52 PM
Rocklobster
Well once you get going on the highway put od back on for the long runs hills might suck tho
post #5 of 22 Old 12-17-2011, 03:54 PM
Rocklobster
Your 4th gear is like a passing gear I dont think unless you reflash the tranny computer you can use it the way you think.
post #6 of 22 Old 12-17-2011, 03:56 PM
Rocklobster
Check wjjeeps.com
post #7 of 22 Old 12-17-2011, 04:37 PM
ZAM
2003 WJ
Are you supossed to use OD while towing? I tow my boat on average 3 times a week (2500lbs) and I don't do anything differently, just put it in drive. I've been doing it for years with no problem. it may be the wrong way though, Im not sure
ZAM is offline
post #8 of 22 Old 12-17-2011, 08:23 PM
chrisstromberg
I turn off OD for towing when I'm climbing hills, but if I'm cruising on a flat highway (Kansas), I drive like normal.
chrisstromberg is offline
post #9 of 22 Old 12-17-2011, 09:04 PM
mycreativename
You're not supposed to use OD when towing, as the constant shifting that the auto tranny will want to do between OD and actual gears will heat the transmission right up, and as we know, heat is the enemy when it comes to transmissions.
However, many just turn their OD off when in hilly terrain/city/areas where the strain on the engine will change, and leave OD on when towing across a flat surface at a constant speed.
Long story short, you'll be fine with OD on as long as your transmission isn't hunting for gears, if you notice it shifting up, down, down, up, etc take it out of OD.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #10 of 22 Old 12-17-2011, 09:45 PM
gphunkplp
i think hes asking how to turn the od off. not whether he should drive with it on. is there a button somewhete?
Sent from my optimus
gphunkplp is offline
post #11 of 22 Old 12-17-2011, 10:04 PM
mycreativename
I wasn't responding to the OP, I was responding to ZAM.
Yes there is a button right on your shifter to turn OD on or off.
post #12 of 22 Old 12-20-2011, 12:06 AM
MiCrOz
As far as I've ever seen, there is no choice to be able to select 4th gear with the 545. If it is possible to flash to 45RFE software, you'll lose the 5th gear, but Im not sure if its even possible to downgrade.
MiCrOz is offline
post #13 of 22 Old 12-20-2011, 12:49 AM
JJAMISON_
2015 JK Wrangler
get a manual tranny.
JJAMISON_ is offline
post #14 of 22 Old 12-20-2011, 02:08 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
od off, except when on long stretches of flat highway at constant speed.
od off also allows the torque converter to lock in 3rd gear, keeping the heat soak in the trans down even more.
ratmonkey is offline
post #15 of 22 Old 12-20-2011, 06:24 AM
Double E
Double E's Avatar
Did you really not know where the button is?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is online now
545rfe slow to engage drive gear. Solenoid Pack? lumpster WJ Grand Cherokee Forum 25 01-06-2017 10:29 PM
545rfe gasket spiro WJ Grand Cherokee Forum 7 12-29-2013 11:46 AM
WJ - 545rfe won't go into reverse. MrBaz WJ Grand Cherokee Forum 6 08-19-2011 08:56 AM
4.7 w/ 545rfe guys come in here! WJeep47 WJ Grand Cherokee Forum 11 08-04-2011 08:06 PM
new transmission pan 545rfe? mcclintock89 WJ Grand Cherokee Forum 0 09-10-2010 02:19 PM
