4WD Select-Trac shifting question - JeepForum.com
post #1 of 7 Old 08-18-2013, 10:24 AM Thread Starter
Woliwi
I have a 2004 4.0 Select-Trac
When in 4 LO, does shifting to 2 or 1 have any affect, positive or negative?
Thanks, Woliwi
Old Man Emu HD Springs * Bilstein 5100/5125 Shocks * Iron Rock Adj. LCA's & UCA's * JKS Adj. Trackbar w/ KOR Durometer Bushings * Moog Super Trail Boss Steering Stabilizer * Addco 1" Anti-Sway Bar w/ Energy Bushings * IRO Rear Ext. Endlinks * KOR .75 Front Poly Spacer * Falken Rocky Mountain LT 265/75/16 ATS on stock Silverblades #1
Woliwi is offline
post #2 of 7 Old 08-18-2013, 11:03 AM
braddf
Well you can't go over 25 and thats pushing it so i wouldnt think that it would matter
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #3 of 7 Old 08-18-2013, 02:55 PM Thread Starter
Woliwi
Yes....I know about the under 25mph in 4 lo....
Was wondering if, while in 4 lo, does shifting out of Drive into 2 or 1 have any advantages/disadvantages (gear ratio) for climbing really steep hills.
Woliwi is offline
post #4 of 7 Old 08-18-2013, 03:08 PM
tim0
Yes it will have a positive and negative affect depending on how you look at it.
It doesnt martter 2wd, 4x4 high or 4x4 low. Same affect. If you put the transmission in normal range or OD to drive, every thing is done automaticaly for you.
If you drop down to 2nd this will limit the transmission from shifting up any higher than 2nd gear.
Same with putting it in 1st, will not shift to 2nd, 3rd and so on.
Positive?
While going down hill it will make the engine help slow down the jeep and maintain a constant speed without using the brakes as much.
While going up hills and long enclines it keeps the transmission from constantly shifting up and back down, keeping from over working the transmission.
Negative?
If you forget to shift back up its very easy to over rev the engine.
tim0 is offline
post #5 of 7 Old 08-18-2013, 05:02 PM Thread Starter
Woliwi
Positive?
Negative?
Thank you very much TimO...That clears things up....mostly. I understand that gear 2 and 1 eliminate any automatic gear changing in any mode, and the possible benefits of a steep descent or maybe a long, slow steady ascent
When in only 4WDlo is there still automatic gear changing? Is 4WDlo as low as it goes? or does 4WDlo and gear 2 or 1 change any gearing?
Woliwi is offline
post #6 of 7 Old 08-18-2013, 08:50 PM
tim0
You still have all gears in the transmission even in 4x4-low that you normally would have had.
Your profile shows you have 4.0 i6.
Which means you have the 4 speed OD trans. So you have OD on or 4th, OD off which will put you in 3rd, then you have 2nd and 1st.
Now in 4x4 low you still have OD or 4th( 4x4 low in 4th gear), when you turn it off you will be going slower, (4x4 low in 3rd gear) then you have (4x4 low in 2nd gear) and (4x4 low in 1st gear).
I use the OD off button every time I'm going down a long hill where I need to keep using the brakes to slow down and just watch the mpg max out.
This will make it use the engine speed to help slow you down just like shifting down with a manual transmission.
Just remember to turn it back on when your over the hill and need to shift back up to 4th.
tim0 is offline
post #7 of 7 Old 08-18-2013, 09:02 PM Thread Starter
Woliwi
Thanks for the info TimO.....
And interestingly, I also took my silver Jeep and two sons wheeling around a lake today.
Woliwi is offline
