4wd light - JeepForum.com
post #1 of 3 Old 10-28-2003, 09:31 PM Thread Starter
baseball_coach
4wd light
I have a 2000 GC select trac 4x4. When the transfer case is engaged into 4wd full time or 4wd low, should a green light indicate this on the dash. The only time I have a green light indicating the 4wd is lock in is when I have selected part time 4wd. Is this correct or do I have a malfuntion in the dash? Thanks in advance>
baseball_coach is offline
post #2 of 3 Old 10-29-2003, 07:29 PM
madmanfrommars
madmanfrommars's Avatar
Well I have the Quadra-Trac on my 02 overland, and I never see any light. I would assume that that light would only show up to make sure you know that you're in 4wd part time (and you're not supposed to stay in it for long)
madmanfrommars is offline
post #3 of 3 Old 10-30-2003, 07:47 AM
BLEVE
The light on the dash is only supposed to come on when you're in 4 wd part time, there's no light for 4wd full or low
BLEVE is offline
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 01:29 AM
OIL LEVEL GAUGE, AIR BAG LIGHT & ABS LIGHT SHOWING ON DASHBOARD - WJ Model babix0ashh ZJ Grand Cherokee Forum 6 01-19-2010 01:48 AM
gcl 4.0 driving light/brake light/turnsignal issues msherman1 ZJ Grand Cherokee Forum 1 01-05-2010 10:23 PM
Super cheap headlight, marker light, directional light kit... thoughts? aaron7 ZJ Grand Cherokee Forum 13 01-07-2009 07:17 PM
Tail Light and Instrument light problem t_guenther ZJ Grand Cherokee Forum 0 09-18-2008 08:27 AM
