4wd issues 2000 Grand Cherokee ltd - JeepForum.com
post #1 of 5 Old 12-14-2011, 07:35 PM Thread Starter
alliedtech12887
Went off roading last weekend and in 4wd hi my front wheels were not engaging. I tried the 4wd low and it seemed to work fine. When I put I back into hi the 4wd hi the front wheels were engaging sometimes and not others. I was thinking a transfer case flush? Also it has a issues when braking kinda hard and approaching stop lights the jeep almost stalls and sometimes does. Could this be part of the issue?
alliedtech12887 is offline
post #2 of 5 Old 12-14-2011, 07:57 PM
mtb_crzd47
Judging by the factbthat you have a Limited I'm guessing you have the V8? If so your t case may not have the correct fluid in it. Get it from the dealer.
2000 WJ LTD Shale Green metallic, stock for now
2007 Yeti AS-X, Avid Code 5's Rockshox Totem,
SOLD: 91 XJ
mtb_crzd47 is offline
post #3 of 5 Old 12-15-2011, 07:07 AM Thread Starter
alliedtech12887
Yes it is a v8. Would you happen to know the type of fluid and amount the transfer case uses?
post #4 of 5 Old 12-15-2011, 07:59 AM
jeepvsgti
it can only be purchased from the dealer. its mopar 247 fluid i believe. bet someone put atf4 in there.
current: 1999 WJ limited quadradrive
RIP: 1982 CJ7 limited, 1986 2 door 2.8l XJ, 1991 XJ ltd, 2001 XJ, 1998 XJ, 1962 willies wagon
jeepvsgti is offline
post #5 of 5 Old 12-15-2011, 10:44 AM
mctwin2kman
My 1999 seems to not be engaging, rears spin in the rain, but it does seem to be engaging a little as the vehicle starts moving and accelerating. More than my XJ would in 2WD. So the fronts are doing something. Seeing as I have only had it two weeks I am changing my fluid tomorrow. Hopefully it will correct it all. Also get two quarts. It takes a hair less but that will fill it.
mctwin2kman is offline
