45rfe transmission swap - JeepForum.com
post #1 of 1 Old 10-11-2013, 10:06 AM Thread Starter
Maximus_Daximus
1976 CJ7
So I recently run into some issues, turns out the rear output shaft and bearings are bad in my trans and it wines to high hell. It's a 99 4.7 with 80k miles. I recently located a few 45rfe transmissions with low miles. However, I've come to find out that Theres a possibility that the 99 wj will o Lu take the 45rfe from another 99. I can't find any actuall info on this. Something to do with the governor sensor and transisitransistor a. And it'll lock you out of od. Any input would help.
current build 1999 wj
previous build 1976 cj7
Maximus_Daximus is offline
