45FRE shift kit..... - JeepForum.com
post #1 of 10 Old 05-06-2012, 10:34 PM Thread Starter
Jeepgcl9947
So I want to add a shift kit, I heard I should get it flashed to a 545FRE first but now I see they make a 6 gear programming for the 545FRE, question is could mine handle 6 gears??? Also how do I go about adding a shift kit I know there purpose but how do I add one. Thanks
Jeepgcl9947 is offline
post #2 of 10 Old 05-06-2012, 11:18 PM
mycreativename
The 6 "gears" are already in there. The 545RFE flash enables a second overdrive ratio, (aka 6th gear), while the 45RFE uses only one overdrive, (5th gear).
As for the shift kit, here's a write up on how to install it, as well as change the fluid, which you might as well do when you open it all up.
http://www.nagca.com/forum/showthread.php?t=33521
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 10 Old 05-07-2012, 09:20 AM Thread Starter
Jeepgcl9947
So would the dealership flash it to a 6 speed, if so how much?
post #4 of 10 Old 05-07-2012, 10:53 AM
mycreativename
Yes, dealership would do it, but I have no idea how much they would charge you. Are you sure no one has done it on your Jeep as of yet?
post #5 of 10 Old 05-07-2012, 11:02 AM
04Overland47
04Overland47's Avatar
I can get my 545rfe flashed to a "6 speed"?!?!?
2004 WJ Overland 4.7HO Graphite 127k miles / Powerstick Muffler / Superchips / Bilstein HD's / Addco Rear Bar / SOLD!
1998 ZJ Limited 5.9 SOLD!
2010 WK Laredo 5.7
2002 WJ Overland 4.7HO
04Overland47 is offline
post #6 of 10 Old 05-07-2012, 12:31 PM
narnwv
narnwv's Avatar
yours already is.
Only the 99-mid 2001 ones didn't have the 6 speed software.
There are 6 forward gears, with two 2nd gears. One for the upshift, one for the downshift when you get on it.
~Aaron
narnwv is offline
post #7 of 10 Old 05-07-2012, 12:35 PM
04Overland47
Originally Posted by narnwv View Post
yours already is.
Oh, I thought it was two different ratios and the computer chooses the one depending on what you're asking it to do (upshift/downshift). Didn't know it was actually two different gears.
2010 WK Laredo 5.7
post #8 of 10 Old 05-07-2012, 06:40 PM
shockracer
Hmm, this is new news to me. I did know my WJ had 6 speeds, so the dealer can flash this and your good to go? Does this help drivablity?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #9 of 10 Old 05-07-2012, 08:47 PM
narnwv
narnwv's Avatar
if you're at 2000 rpm while going 70, you already have the flash. Both second gears come from the factory on all models, 99-mid 2001 didn't have the "second overdrive" which the software flash takes care of.
Personally, living in a hilly area, I wish I didn't have the second over drive (5th gear), especially after bigger tires. I down shift way too much at highway speeds (55+, hitting mountains)
~Aaron
narnwv is offline
post #10 of 10 Old 05-07-2012, 08:52 PM
narnwv
narnwv's Avatar
Those two things are the same thing.
~Aaron
narnwv is offline
