44a axle swap, d/s lenght, what do you think? (pics) - JeepForum.com
post #1 of 9 Old 05-18-2011, 12:35 PM Thread Starter
TJSWJ
Im in the process of doing my axle swap, and im worried i may have to get my d/s shortened but its really a close call. I know most people shorten their d/s 1.5" but im at about 5" of lift. Im thinking i may need to shorten it about 3/4" just to be safe. I dont want the driveshaft shattering the t-case. What do you guys think?
This is at full extension, tires hanging in the air, with frame of jeep supported by the lift.
This is at full compression, shocks a hair from bottoming out.
This is just to give you an idea of how long the splines are
TJSWJ is offline
post #2 of 9 Old 05-18-2011, 12:48 PM
mudtrackerinc
mudtrackerinc's Avatar
i would think your good to go as is
02WJ Rough Country 4" Long Arm,3/4 spacers added to front,265x70x17C BFG All-Terrain T/A KO 31.8x10.7,super 44 flowmaster,K&N air filter,JKS adj track bar,JKS HD tie rod,JKS HD draglink,RCX dual stabilzer,Mickey Thompson Sidebiter wheels 17x9 4.5"BS,Saguaro4x D-Ring Mounts
06tj RC 4" X-series ,RC Dual Steering Stabilizer, 32x11.50x15 BFG All-Terrain T/A KO, 15x8 Ultra Motorsports Rogue
Model:175 Wheels, K&N CAI & Filter,super 44 flowmaster
mudtrackerinc is offline
post #3 of 9 Old 05-18-2011, 12:49 PM Thread Starter
TJSWJ
only benifit i see leaving as is, is reducing the chance of driveline vibes. Seeing as how the d/s is at less of an angle with it being closer to the t-case, plus it will have plenty of spline engagement.
only downfall i see is there only being roughly 3/4" of forward travel before it hits the t-case, but then again the shocks would over extend well before that ever happened.
TJSWJ is offline
post #4 of 9 Old 05-18-2011, 01:14 PM
FirefightinWJ
I'm at 5.5" of lift and did not need to shorten at all. You want around 1.25" of shaft showing at ride height. I wheeled pretty hard a few weeks ago (first run with the 44a) and have no problem with rear driveshaft.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #5 of 9 Old 05-18-2011, 06:51 PM Thread Starter
TJSWJ
awesome, im going to let it go then and see what happens. Thanks everyone!
TJSWJ is offline
post #6 of 9 Old 05-18-2011, 11:28 PM
Jason_alex
Nice to see pics and the drive shaft info... planing on doing this next month.
2001 Jeep Grand Cherokee Laredo 4.0L Selec-Trac 2.5" ROR lift
1977 Trans Am 400 bored 40 over new paint new sub-frame.
Jason_alex is offline
post #7 of 9 Old 05-19-2011, 03:23 AM
10achik
I ate what?
10achik's Avatar
Let it be, looks great as is. I'm at 6.5" and mine looks almost the same as yours. It's been this way for a couple years and I've had no issues on or off road.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #8 of 9 Old 05-19-2011, 03:31 AM
PhantomWJ
2003 WJ
Looks fine...grease the splines and/or put a boot on it...a shock will work.
PhantomWJ is offline
post #9 of 9 Old 05-19-2011, 07:29 AM Thread Starter
TJSWJ
Yep I greased it and put the factory boot back on.
TJSWJ is offline
3 inch lift, which shock lenght??? Geo-Nemesis WJ Grand Cherokee Forum 7 01-19-2012 03:58 PM
D35-->D44a axle swap ArloGuthroJeep WJ Grand Cherokee Forum 67 11-17-2011 12:27 PM
Front Axle Swap Mud_Crazy WJ Grand Cherokee Forum 13 11-03-2010 12:04 PM
WJ V8->I-6 front axle swap dkpulsford WJ Grand Cherokee Forum 3 05-17-2010 01:02 AM
direct fit axle swap? TJSWJ WJ Grand Cherokee Forum 6 03-31-2010 06:34 PM
