42re, P1762 and P1763, Governor pressure sensor & Solenoid write-up - Page 7 - JeepForum.com
post #91 of 197 Old 02-04-2013, 12:57 PM
Chefdio
I called the dealership today and told him about it and AGAIN have to take it all the way to the middle of down town Orlando traffic, hoping that they will change it and put another sensor. I'm not even sure if they even put one at all, I was charge for it but I just donít trust anyone anymore.
Today, early, I took the vehicle to a mechanic who I know in the area and asked him to check the code number and this is what came on the devise:
Code PO987, Transmission Fluid Pressure Sensor Switch E - CKT.
I'm not sure if this sensor was defective or not, but they told me I have 12 months on parts and labor if I've got the parts and labor over the delarship. I really hope that would be the problem.
Chefdio is offline
post #92 of 197 Old 02-15-2013, 03:06 PM
bigjohnsondohc
I just did this and have a problem. There is a tapping sound coming from the transmission when I put it into drive, I am not sure what it is. I must have done something wrong.
bigjohnsondohc is offline
post #93 of 197 Old 03-05-2013, 11:16 AM
chrisc909
2003 WJ
Weird issue after fix.
Great write-up. I'm a computer geek and although I fix the various things on my wifes jeep, was afraid to touch the transmission. My 03 WJ was stuck in 1st gear. Followed this write-up, and now I'm driving again. Thanks fireman. The info was invaluable and saved me a lot of money. This also fixed my oil leak and burning smell problem. Guess it wasn't oil . One issue I seem to have now is that the transmission runs great as long as I don't put my foot in it. If I jump on the freeway and press hard on the pedal, the 3rd gear (assuming) seems to rev all the way to 5500 RPM and wont shift. If I let of the gas, it will. If I coast at 65 and jump on it, it seems to drop into 3rd, and then will shift twice after I let off the gas. Its my wife's car, so I don't drive it much. Just keep having to fix it . I did use the Cascade kit with the Borg. At this point, we just drive it normal and it seems to be fine. Just worried for what it may cause down the road. Any ideas would be appreciated.
Today I will start the CCV elbow and grommets replacement. You guys have created a monster. I used to have free time (but less money).
chrisc909 is offline
post #94 of 197 Old 03-11-2013, 07:10 PM
koww80
stuck sensor
i cant get the sensor out of the valve body
koww80 is offline
post #95 of 197 Old 03-11-2013, 07:28 PM
chrisc909
2003 WJ
On mine, you have to remove the plate before the sensor pops out. Look on page 1.
post #96 of 197 Old 06-17-2013, 08:26 PM
Buckslayer
How much ATF do I need to complete this? I didn't get an owners manual. I have a 04 special edition with the quadra trac II with a 4.0l.
Buckslayer is offline
post #97 of 197 Old 07-24-2013, 09:03 AM
lmillandiaz
has anyone come across the torque specs for the internal parts that need removed and the oil pan?
lmillandiaz is offline
post #98 of 197 Old 07-25-2013, 06:59 AM
admoseley
1999 FSJ Cherokee
Looking through the Jeep parts catalog (http://www.covertchryslerdodgejeepra...ts-catalog.htm) and RockAuto.com, the parts in this write up has to be for a Jeep year 2000 and higher? I have a 1999 and I can find the Governor component and the pressure sensor, but the naming is slightly different on the jeep's part site where I found them, there is also an extra "Overdrive component" between them unlike what I'm seeing in the write up.
Can any help me verify that these would be the parts for a 1999 Grand Cherekee Laredo V6 4wd? I have a jeep that's acting the exact same way as the original poster.
The part name/numbers match the labels on the picture.
30 - SOLENOID TRANSMISSION GOVERNOR
5 - TRANSDUCER PRESSURE SENSOR
4 - SOLENOID TRANSMISSION OVERDRIVE
7 - FILTER VALVE BODY
Any help is appreciated.
admoseley is offline
post #99 of 197 Old 07-27-2013, 12:00 PM
drrm123
1994 ZJ
Admoseley the parts are the same. As for the extra part if your referring to part #4, that's on the OP trans too. If you think your jeep has a V6 I don't think you should attempt this. LOL
2001 Jeep Grand Cherokee Laredo 6 cylinder Selectrac
$2400 installed new radiator 1 window regulator 2 oxygen sensors
drrm123 is offline
post #100 of 197 Old 08-25-2013, 03:31 PM
Ruppert
42re shift issue
I read thru the entire thread and this seems to reflect my issue(s)... Stuck in first. Replaced pressure solenoid and transducer, filter and 3-4 spring. I still have similar symptoms, from first, shifts to neutral, let off gas and catches 2nd, seems to waver between 2nd and 3rd. I did not, however remove the battery cable. Must I clear the codes in order for system to recognize replaced parts?
Ruppert is offline
post #101 of 197 Old 08-26-2013, 07:25 PM
sixmikey9
2003 WJ
I had your symptoms...replaced gov sensor & solenoid, still didnt help. Pulled tranny (42re), pulled it apart & found my rear clutch pack was absolute toast. So im in the middle of putting it back together with new parts! Yay.
sixmikey9 is offline
post #102 of 197 Old 10-19-2013, 02:18 PM
1slo_camaro
I really hope this will help, if not hopefully this bumps it up to someone else. long story short the puddle was deeper then expected i know i sucked up a little water but the trans held tight through the rest of wheeling (maybe another hour with a good 20 min rest in between) i immediately went to autozone and changed fluid (no filter) and went home she never shifted out of second even with manual shifting. Hopefully i still have a good sensor and solenoid sitting at my house, and i will refill my trans with fluid and a quart of lucas and fingers crossed this is the issue. my jeep has been down for the last year and this was the second time shes been out playing so i really really want/need my jeep for the upcoming winter months.
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #103 of 197 Old 10-25-2013, 08:22 PM
shipley
First time ever on a forum of any kind. I have an 03 GC limited 4.7. I was told that it needed a transmission line pressure sensor, no big deal. The pan is off..... where the heck is the sensor?? Would appreciate any advice ASAP!
shipley is offline
post #104 of 197 Old 10-25-2013, 09:18 PM
brouwmat
brouwmat is offline
post #105 of 197 Old 10-25-2013, 09:19 PM
shipley
Big mistake trying to DIY. Can't find the Trans pressure sensor on my 03 jeep. Everything that I have read & watched has not helped find it. Ordered the part that the dealership said I needed but I just can't figure out where it goes! Cleaned the pan etc and put it back on. Was hoping for some advice but I don't even know if anyone is reading this but me.
shipley is offline
Replaced the Gov Sensor & Solenoid...lights gone not the problem crflugga WJ Grand Cherokee Forum 9 02-07-2011 09:09 PM
Governor Pressure Sensor tennesseewj WJ Grand Cherokee Forum 1 10-29-2010 01:16 PM
Governor pressure sensor mikebuchan WJ Grand Cherokee Forum 1 09-23-2010 06:34 PM
'02 P1763 again !!!!! mikey531 WJ Grand Cherokee Forum 6 07-03-2010 05:26 PM
Replaced governor pressure solenoid & sensor today, still slipping... GCherokee2001 WJ Grand Cherokee Forum 18 06-15-2010 03:01 PM
