42RE Fluid and Filter Change - JeepForum.com
post #1 of 10 Old 08-19-2014, 07:40 AM Thread Starter
doityourselfMM
doityourselfMM's Avatar
Time for new fluid and filter on the 04 I6 42RE transmission. I've done this before, but it's been a while and my brain is 'high mileage'.
I know the gasket is reusable, but does it require RTV? For this trans & gasket, I think not.
Does the filter have a gasket/seal, other than the one in the filter itself?
Pretty basic questions, but I just want to have the right parts and materials on hand before the job ... not in the middle of it!
Thanks.
doityourselfMM is offline
post #2 of 10 Old 08-19-2014, 07:53 AM
ChrisHager
Administrator
ChrisHager's Avatar
I always smear a little RTV on each side of the gasket that comes with the filter kit. This helps hold the gasket in place while installing the pan and also reduces possible leaks.
As for the filter, it is held in with 2 bolts. The mounting surface of the filter typically has a cork gasket already installed.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #3 of 10 Old 08-19-2014, 07:57 AM
Jeeples
Jeeples's Avatar
I've always installed rubber gaskets of any kind sans any type of sealant. On the 545RFE in my wife's WJ I did the trans fluid and filter 3 years ago and used the Power Torque brand filter kit from O'Reilly and the rubber gasket and outside of the pan are still free from any leaks. That being said, I know I've read several threads recently where Mopar is spec'ing their specific RTV type for all transmission pans now. Some folks on the forum have followed that recommendation, others have gone the traditional rubber gasket route. Both seem to have had good luck with their respective procedure.
The filter itself will have a seal that pops into the pickup tube like most auto transmissions.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #4 of 10 Old 08-19-2014, 08:10 AM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by Jeeples View Post
...Both seem to have had good luck with their respective procedure...
That's really what it boils down to, it seems. Pick your favorite method and have at it. Just be sure not to glob on the RTV if you choose that route.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 10 Old 08-19-2014, 09:28 AM Thread Starter
doityourselfMM
Thanks for the replies!
After I got over being lazy, I pulled out the FSM. With this particular type of rubber (reuseable) trans gasket, no RTV is needed. With other transmissions, yes. And the only gasket needed for the filter, is the one attached to it. I think the 545 trans has a seperate filter gasket that needs to be seated.
By the time I bought 6 quarts of ATF, 2 quarts of NV247 oil, 4 quarts of 75W-140, 6 quarts of 10w-30, oil and trans filters, 6 NGK plugs, and the trans gasket .... I was pushing $300. And that's with discounts. That 60k mile service isn't cheap! At least the labor is free.
post #6 of 10 Old 08-19-2014, 10:01 AM
dcorn
Word of caution. If you pry on the trans pan to get it off, make sure it's dead flat before you put it back on. I used a new rubber gasket and my stupid pan is leaking from the back corner when I pried on it to remove it. Shoulda just used the RTV and not the rubber gasket.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #7 of 10 Old 08-19-2014, 10:16 AM
WXman
And I think the internal filter has torx style screws holding it in place so make sure you have a set of small torx sockets available before dropping the pan.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #8 of 10 Old 08-19-2014, 10:30 AM Thread Starter
doityourselfMM
I think the last time I removed the pan, I loosened the bolts about 3/8", then tapped downward on the edge of the pan with a rubber mallet and a small block of wood. G-E-N-T-L-Y!
I have Jeeps. First order of business was buying a complete set of internal and external torx. Nuff said!
post #9 of 10 Old 08-19-2014, 01:03 PM
BIGBADWOLF
Reuse old gasket without any sealant. Pan should fall off unless someone has put sealant on it before. Do not overtighten bolts and torque them in a crisscross sequence and it will not leak. If this procedure was not followed in the past it may leak!
BIGBADWOLF is offline
post #10 of 10 Old 08-19-2014, 01:08 PM
ReclusiveXen
1997 XJ Cherokee
The 1-2 bolts on the rear right of the pan you need a ratchet extension bar because of that stupid exhaust bracket that has to be in the way. Lol, last time I did mine I did actually strip 2 bolts but I still got like 10 holding the pan on so, oh well.
ReclusiveXen is offline
