42re diagnosis - JeepForum.com
post #1 of 3 Old 01-30-2014, 03:03 AM Thread Starter
clute75
Unhappy 42re diagnosis
so i just put another engine in my jeep and when i started it up and checked for leaks i had tranny fluid leaking out of the bell housing. i did replace the pump seals and torque converter prior to putting the motor in and the motor and trans went in at once. the torque converter was fully seated in the tranny before putting the two together and the motor started and ran high idle due to timing issues but besides that normal. what did i do wrong? any ideas?
clute75 is offline
post #2 of 3 Old 01-30-2014, 08:20 AM
88yjproject
Could be a seal not installed properly or a bad converter sealing surface. also the transmission vent is on the pump and fluid could be too full. Try cleaning it out and running it and see what happens.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #3 of 3 Old 01-30-2014, 04:25 PM Thread Starter
clute75
i pulled the tranny and pump today and checked all the gaskets and seals they were all good . when it starts it sounds like the torque converter clunks into place so we are going to go back and make sure we got the converter for the 42re not the 44
clute75 is offline
