4 wheel drive noises? - JeepForum.com
post #1 of 3 Old 02-25-2012, 11:32 PM Thread Starter
jeepassassin
Wj 4 wheel drive noises?
When I put my jeep into 4 wheel drive all time or 4 lo, it makes a terrible grinding noise while driving. It will shift in and out of 4 wheel fine, but just makes bad grinding noises while driving it in 4 wheel drive? Also I can here a faint grinding noise while driving in regular 2 wheel drive? Sounds like its coming from directly under the middle of my center console and dashboard?
Driving me crazy! please help.....
jeepassassin is offline
post #2 of 3 Old 02-26-2012, 01:10 AM
85IrocZ-28
Here is the process I use to move into 4lo:
In drive, I let off the brake and begin moving forward.
I then shift the transmission into neutral.
While in neutral, and moving at a slow walking speed, I shift the t-case into 4lo.
Place the trans back in drive.
Have Fun!
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #3 of 3 Old 02-26-2012, 02:55 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Doesn't sound like a shifting issue, as it shifts just fine per the OP. Sounds more like a "once I've shifted it into 4WD, it makes awful noises".
I would say the most likely culprit is the Rzeppa-joint front driveshaft. It's a common failure item. Unfortunately, diagnosing via the internet is pretty difficult. If you aren't confident my diagnosis from 2300 miles away, have a professional take a look. Good luck!
~Richard
billzcat1 is offline
'99 No 4 Wheel Drive dinske WJ Grand Cherokee Forum 4 02-24-2012 01:51 PM
WJ Quadradrive auto making ticking noises while in park and jerking around in drive OzzyWJ WJ Grand Cherokee Forum 9 04-23-2011 03:15 PM
No 4 wheel drive in 4HI SpiderViper WJ Grand Cherokee Forum 9 02-06-2011 06:36 PM
all wheel drive/4 wheel drive/transfer case problem greta WJ Grand Cherokee Forum 10 12-29-2010 08:25 AM
So how rare are 4.7 H.O. With 2 Wheel drive? kukri WJ Grand Cherokee Forum 16 10-19-2010 05:08 PM
