4" lift shocks for 3" lift - JeepForum.com
post #1 of 10 Old 10-24-2013, 11:36 PM Thread Starter
04beachwheeler
Friend of mine ordered Bilstein 5125s for his 4" long arm kit but decided to go higher...i bought them from him but i have a 3" lift. considering another one of my buddies is running 4" springs on his 3" lift without any problems i assumed it was fine. and considering i will most likely never reach the full limits of my suspension i didnt think i'd bottom out the shock. am i alright here?
04 WJ: 4.5' Clayton F, 4" IRO R, IRO adj front control arms, Ruffstuff OTK one ton tie rod, OBA.
04beachwheeler is offline
post #2 of 10 Old 10-25-2013, 12:53 AM
Kolak
Vendor
Kolak's Avatar
What are the extended and collapsed lengths or part numbers of the shocks you bought?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #3 of 10 Old 10-25-2013, 05:35 AM
tufmar
For 3" of lift just make sure you dont exceed the following for your collapsed lenght : Front: 15.3" and rear: 15.6"
93 YJ - 4.0 2" BDS 1" BL 33's
98 ZJ - 5.2 Limited 2" BB 31's
02 WJ - 4.7 Laredo 242 TC 3" IRO 245/75's
tufmar is offline
post #4 of 10 Old 10-27-2013, 07:01 PM Thread Starter
04beachwheeler
Got the part numbers for the shocks I bought. They are from IRO for a 4" lift but I've heard they will work for a 3" lift just fine. Here is the email IRO sent my friend from whom I bought the shocks from.
post #5 of 10 Old 10-27-2013, 07:06 PM Thread Starter
04beachwheeler
Are these shocks valved only for a wj with a 4" lift?? Will I run into problems if I don't go to 4"?
post #6 of 10 Old 10-28-2013, 12:31 AM
Kolak
Vendor
Kolak's Avatar
The 33-185606 is a universal loop/loop shock. No doubt IRO included adapters when he purchased them. He's including those with the shocks, correct?
The 33-185552 is also a universal shock. You'll need the correct WJ bushing sleeves so they don't clunk.
Extended and collapsed lengths are acceptable for your lift. The rear may be a little on the long side so check for adequate up-travel and extend the bumpstops if need be.
or
Kolak is offline
post #7 of 10 Old 10-28-2013, 05:26 AM Thread Starter
04beachwheeler
The 33-185606 is a universal loop/loop shock. No doubt IRO included adapters when he purchased them. He's including those with the shocks, correct? The 33-185552 is also a universal shock. You'll need the correct WJ bushing sleeves so they don't clunk. Extended and collapsed lengths are acceptable for your lift. The rear may be a little on the long side so check for adequate up-travel and extend the bumpstops if need be.
IRO did include the adapter for the front shocks. There already also the correct metal sleeves in the bushings in the proper places. Since they are "universal" will they not necessarily be correctly valved for the wj? Or are these the same shocks you would ship out for the same application?
post #8 of 10 Old 10-28-2013, 05:35 AM
Kolak
Vendor
Kolak's Avatar
Those shocks are technically the 5125 series. They are 255/70 valved. The 5125 series has a 90 day warranty. I think you'll find that they perform and ride well, but if I were shipping you a set, I'd ship the 5100 series. These would not require the adapters up front, not require additional WJ bushing sleeves for the rear, have a lifetime warranty, and be specifically valved for the WJ.
or
Kolak is offline
post #9 of 10 Old 10-28-2013, 06:16 AM Thread Starter
04beachwheeler
Alright thanks, just making sure these would fit on my jeep. I also had a question as to how they are mounted...front and rear both mounted with the words so they are right side up?
post #10 of 10 Old 10-28-2013, 01:44 PM
Kolak
Vendor
Kolak's Avatar
They will work either way but mount them with the shaft at the bottom if possible.
or
Kolak is offline
