4.7L V8 stroker!!! - JeepForum.com
post #1 of 27 Old 02-27-2013, 11:07 PM Thread Starter
mdrum93
Wj 4.7L V8 stroker!!!
I know the 4.0L can be stroked out, but is there a particular reason why I cannot find anything on a stroker kit or a thread for stroking out the 4.7L V8? It seems like it would have been done by now if it could be.
If it can be done, what would the new displacement be and what are some numbers this mythical stroked v8 could produce???
mdrum93 is offline
post #2 of 27 Old 02-28-2013, 03:41 AM
Gunrunner23
You would also think that someone would make non aluminum heads.....
Sent from my Motorola Photon using JeepForum
2004 wj limited 4.7
IRO 3in lift with skyjacker hydro
265/75/16 TreadWright Claws
Gunrunner23 is offline
post #3 of 27 Old 02-28-2013, 04:10 AM
alfaitalia
And why not go back to acetylene lamps for lights and cart springs for suspension......only joking.
No need to go back to steel heads.....just make the ally ones correctly in the first place. Just about every other manufacturer in the world has managed it ok!
They seem to last ok for most people....as long as you dont overheat them.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is online now
post #4 of 27 Old 02-28-2013, 04:44 AM
Gunrunner23
Yes but I've also seen people on here grenade the 4.7 in the winter without overheating. For peace of mind ill take the steel heads. Because obviously it was an issue that they didn't want to correct in all the years, makes, and models the 4.7 was alive.
Im not saying I don't take care of my jeep but there have been several people who its happened to who have claimed they baby their wj. Im also friends on facebook with a local jeep only shop and I see once a month they post a pic of a dropped seat valve. And they are replacing it with a jasper, atk, etc.
2004 wj limited 4.7
post #5 of 27 Old 02-28-2013, 05:49 AM
alfaitalia
I would not mind betting that a high percentage of those have been overheated at some point.
post #6 of 27 Old 02-28-2013, 06:20 AM
Gunrunner23
Oh no doubt, also probably not running the correct coolant.
2004 wj limited 4.7
post #7 of 27 Old 02-28-2013, 09:05 AM Thread Starter
mdrum93
Would it be possible to make cast iron heads using the aluminum heads as a model? Seems like you could take the bare alum head and make a sand mold with it and then pour cast iron into it, and then have them professionally planed and machined/cleaned up to specification
I know it would be a lot more complicated than that, but if you have experience with casting metal from sand molds, would it be worth the effort?
Bumper Thread
mdrum93 is offline
post #8 of 27 Old 02-28-2013, 09:17 AM
Gunrunner23
Im sure if u sent the aluminum ones edelbrock and they might be able to make some but it would probably cost a lot.
2004 wj limited 4.7
post #9 of 27 Old 03-01-2013, 10:42 AM
multmigs
2003 WJ
why would edelbrock or anyone else bother to make a cast iron head? Try to find a single performance engine that runs better with that versus either a factory alum head or an aftermarket company's version, YOU CAN'T..... These Mopar 4.7 heads were clearly a bad design from day one, and the engine rebuilding companies all know this which is why they clearly state in all their ads that they have an improved version with the valve seat issue addressed. Its not like this stuff never happens elsewhere, the early Hemi V8 2005/06 has almost the same exact story. Again its bad initial engineering it seems and nothing to do with the material choice. How do you explain the notorious cracked CAST IRON 4.0 cylinder heads that were found in 2000/01 XJ/TJ vehicles if that material is so great? How many people had a entire motor replaced thanks to coolant in the oil on those?? Whats next you would rather have a non plastic intake manifold made up to resist cracking?
multmigs is offline
post #10 of 27 Old 03-01-2013, 10:57 AM
ZeJokee
Actually I would! But they cost too much.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #11 of 27 Old 03-01-2013, 10:58 AM
rcwj04
They only want a iron head to save the engine if it is to overheat, aluminum heads have a lower melting temp than the iron block. They are not doing it for performance
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #12 of 27 Old 03-01-2013, 11:25 AM
Gunrunner23
Yeah I could care less about performance. I know that jeep went with aluminum because of the performance. Doesn't change the fact that it warps when over heated. Steel/cast iron won't do that. Id sacrifice a little performance for peace of mind. But hey maybe that's just me. I mean I know I don't have 2700 dollars laying around for an engine.
Also plastic intake manifolds are cheaper to replace then an engine....... So chill
2004 wj limited 4.7
post #13 of 27 Old 03-01-2013, 11:27 AM
Gunrunner23
2004 wj limited 4.7
post #14 of 27 Old 03-01-2013, 12:51 PM
multmigs
2003 WJ
I really don't think anyone understands your last statement at all, what kind of intake manifold would not be cheaper to change THAN (SP) an entire engine?
That nonsense disregarded if this is your opinion why do you bother ranting about stuff like this on a thread that is questioning performance, specifically wanting more performance? How bout keeping your non technically correct answers limited to someone asking something in that same area, like how to cheaply fix something....
multmigs is offline
post #15 of 27 Old 03-01-2013, 01:01 PM Thread Starter
mdrum93
Why so hostile? But seriously i really like the composite intake manifold because it doesnt conduct as much heat and weighs probably 30 pounds less than a metal version of it.
It may not be as appealing to see plastic on an engine but i like it.
But this thread has gotten way off topic!!
Bumper Thread
mdrum93 is offline
