4.7L Seized? - JeepForum.com
post #1 of 15 Old 11-05-2013, 05:31 PM Thread Starter
Seesaw
4.7L Seized?
So while driving to work today my WJ quit and rolled to a stop. Mechanic says the engine is seized - can't get it to turn with a breaker bar. No evidence of what may have caused it. I've had it for 8 years and had no trouble, never overheated, oil level was fine, no metal shavings, nothing. New engine or might there be some known issue with a less expensive fix?
Seesaw is offline
post #2 of 15 Old 11-05-2013, 05:59 PM
Double E
Double E's Avatar
Miles, maintenance, oil used, what does a borescope show? If a cylinder was hydrolocked, which one?
If a valve seat dropped, it should show with a borescope too. A post-mortem might not be tops in your agenda...however.
Now what to do... a re-man will be $3500 or so but may not include labor.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 15 Old 11-05-2013, 06:23 PM Thread Starter
Seesaw
145,000 miles. 4wd. Selec trac. I was very regular with scheduled and recommended maintenance. Mechanic changed the oil so I am not sure the brand or weight. I don't believe a bore scope was used and not aware or any hydro locked cylinders. Mechanic quoted remanufactured engine at 4k and labor 2k. Related parts like water pump, gaskets and plugs another 500. I guess I was hoping there might be some known issue that would lead us to a solution other than a new engine. Not sure it's worth the cost.
Seesaw is offline
post #4 of 15 Old 11-07-2013, 02:21 PM
Double E
Double E's Avatar
It's not unless you just like it enough to put 6k into it and risk other things breaking after. . Would sure be nice to know what happened though.
Double E is offline
post #5 of 15 Old 11-07-2013, 02:34 PM
Jeeples
Jeeples's Avatar
So I assume cranking with the starter is a no go? If he was attempting to turn the engine with a breaker bar, make sure he had the transmission and transfercase in neutral.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #6 of 15 Old 11-07-2013, 04:03 PM
PackLifeNC
I had my wj seize two weeks after I bought it from the dealership. It had 85k on it and I ended spending 5300 for a replacement.
www.packlifenc.com
PackLifeNC is offline
post #7 of 15 Old 11-07-2013, 06:05 PM
Double E
Double E's Avatar
Not a bad idea to check. Heck a second opinion might be worth it since it's a total loss potential.
What is being certain worth these days?
Double E is offline
post #8 of 15 Old 11-08-2013, 09:43 AM
Jeeples
Jeeples's Avatar
Exactly.
I know the 4.7 is far from a perfect motor, and they can have their fair share of mehcanical issues. However they usually don't just up and die or seize up without some form of warning or neglect.
Jeeples is offline
post #9 of 15 Old 11-08-2013, 11:30 AM
imaguy3
Originally Posted by Seesaw View Post
Mechanic changed the oil so I am not sure the brand or weight. .
make sure he didn't screw anything up with that...
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #10 of 15 Old 11-08-2013, 01:24 PM
gdp
I just bought an 04 JGC with 124k miles and seized motor. the oil was molasses and one connecting rod was snapped. getting a used motor with 91K miles for $1500
2001 Grand Cherokee Limited 4.7L Quadradrive
gdp is offline
post #11 of 15 Old 11-16-2013, 06:23 PM Thread Starter
Seesaw
Ok, the postmortem: rod bearing went bad for some reason and the rod/bearing ended up "welded" to the crank. My wallet is a bit lighter but with a replacement engine I'm up and running again.
Seesaw is offline
post #12 of 15 Old 11-16-2013, 07:20 PM
shockracer
Hate to hear you had to go through all that, but glad you didn't off load it to a junkyard, way to keep it on the road!
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #13 of 15 Old 11-18-2013, 05:54 PM
pentastarguy
2015 JK Wrangler
what the cost of the engine and install? tks
pentastarguy is online now
post #14 of 15 Old 11-18-2013, 06:35 PM Thread Starter
Seesaw
4500 for the engine. 2200 labor.
Seesaw is offline
post #15 of 15 Old 11-18-2013, 06:43 PM
Jrboarder27
Now that's a sign of true love
Sent from my Galaxy S4 using JeepForum
Jrboarder27 is offline
