4.7L runs 5 sec and shuts off. - JeepForum.com
post #1 of 4 Old 10-15-2013, 04:38 PM Thread Starter
johnmcm1
Hello,
I have a 2002 GC Laredo. When I start it, it will run for about 5 sec. and shut off. During the 5 sec I can run up to any RPM I want and then it dies. Checked MAP. 4.7 V key on. About 1.1V at start. Fuel pressure is 55 PSI measured at rail. I have no codes after 10 cycles. Any ideas?
johnmcm1 is offline
post #2 of 4 Old 10-15-2013, 07:28 PM
mycreativename
That sounds like it could be a sentry key issue. Do you have a remote start on your WJ? I had one where the chip had become dislodged from where it needed to be and my Jeep would not run without me disconnecting the remote start.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 4 Old 10-15-2013, 08:30 PM Thread Starter
johnmcm1
Pretty close. I was using the hide-a-key. When I switched to the normal key it runs fine. The SKIM or VTSS system was shutting down the engine. Just went out and ran it around the yard. Will do a road test tomorrow.
johnmcm1 is offline
post #4 of 4 Old 10-16-2013, 08:53 AM
Jeeples
Jeeples's Avatar
Right. If your Hide-a-key doesn't have the RFID chip built into and/or isn't programmed to the SKIM/VTSS, the vehicle won't run for more than a few seconds.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
