4.7L Crankcase breather question - JeepForum.com
post #1 of 10 Old 06-03-2013, 09:10 PM Thread Starter
jkelley429
Wj 4.7L Crankcase breather question
Several months ago I had a local mechanic replace the valve covers on my engine.
It seemed to run fine since then, but today as I was replacing the spark plugs I bumped the drivers side crankcase breather that threads into the cylinder head and broke it. Apparently the mechanic had broken it and decided to super glue it back on instead of telling me it broke.
My question is, will it affect anything being disconnected until I can get it fixed? Also, are there any alternatives to fix it such as putting an individual breather on it? Its only $15 for the part but if I can put an individual breather on I would rather just do that.
I tried searching but all the threads for ccv were for the 4.0.
2001 Grand Cherokee WJ Limited- 4.7L Selec-Trac
Cherry Bomb Vortex Muffler- Everything else stock for now
jkelley429 is offline
post #2 of 10 Old 06-06-2013, 09:01 AM Thread Starter
jkelley429
Come on guys, 89 views and no replies?
post #3 of 10 Old 06-06-2013, 09:42 AM
01ShowMeWJ
I haven't seen mine in awhile but I'm sure you can replace it with a aftermarket cone filter. I've done it before on a Dodge pickup V6. They sell them in the same section as the cold air intake kits. It was a direct filter and got rid of all the tubing involved with it. Your WJ shouldn't run bad with it off it just may spit a little oil in your engine compartment. You could always tape a rag over it to keep debris out.
01ShowMeWJ is offline
post #4 of 10 Old 06-06-2013, 09:48 AM
Double E
Double E's Avatar
Got picture? I can't picture mine but I think a JY visit would do the trick, right?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #5 of 10 Old 06-07-2013, 04:12 PM Thread Starter
jkelley429
I found the factory replacement that threads into the head on ebay for $20. It comes with driver and passenger side. I will probably do cone filters on the replacements.
post #6 of 10 Old 09-23-2014, 01:01 AM
Laredo2000
How hard was it to get the broken breather out of the head?
Laredo2000 is offline
post #7 of 10 Old 12-01-2015, 01:25 PM
Double E
Double E's Avatar
Funny that since I wrote that post in 2013, I've now broken my own on the passenger side and know exactly what and where it goes. It is part #53030850AB.
Dealers near me are selling it for $4.25 & 4.99. Don't know when it broke.
I was thinking of just gluing it back together until I learned how much it cost. Apparently there is some sort of thread sealant on this thing too and combined with the location, it's going to be fun to remove/replace. Mine has been broken for some time as I can see some oil weeping down the back of the block. I imagine that it is letting in air to the intake as well.
Perhaps this is what's causing my occasional engine stumble at highway speeds?
Double E is offline
post #8 of 10 Old 12-01-2015, 08:27 PM
thecause17
I need to look into replacing mine. They must have changed this somewhere along the line or in different applications because my '07 Dakota only had one, and it was metal.
'14 F-150 Ecoboost Super Crew 4x4
'97 ZJ 4.0 SOLD, '04 WJ SE 4.0 TOTALED, '03 KJ SOLD, '07 WK Hemi QD SOLD, '04 Columbia 4.7HO SOLD
thecause17 is offline
post #9 of 10 Old 12-02-2015, 09:01 AM
Breadfan
Breadfan is offline
post #10 of 10 Old 01-06-2016, 03:57 PM
Double E
Double E's Avatar
Update: I did end up gluing it back together and also swapped the driver for the passenger side. The broken passenger side one looks like the clearance is so tight on it, that a good twist of the engine on it's mounts would create contact.
SO the glued together one is on the driver's side where it will see no contact. I'll check it to see how it did this week. My nearest dealer did not have them and I was too busy to go to the further away dealer when I had some epoxy in my hand... It also removed from the screw-in fitting easily with a large hex key.
Don't know if it solved the stumbling issue yet.
Double E is offline
