4.7 V8 got hot, gasket gone, How far do I go - JeepForum.com
post #1 of 12 Old 07-14-2013, 02:42 AM Thread Starter
kfxnando
4.7 V8 got hot, gasket gone, How far do I go. new info with video
Dec 2012, we went away, drove to destination, no problem, drove around there no problem
on the way home no problem(total trip 1800km), 2km before home, traffic was blocked up, sat and idled, and saw temp go up, yep on a hot day and aircon working
temp went up to 3/4, my jeep does not have temp specific markings
and it normally runs just below 1/2
pulled off the road, switched off and checked every thing
started up, heard the fan come on, temp dropped to normal and been keeping an eye on it, however its not a DD
last weekend, was looking around, pulled of the radiator cap,(vehicle had been standing for over 24hrs) as I have had to top up the water bottle twice this year
and on the radiator cap(replaced Dec 2011) there was a little bit of like a brown source, smelled and did not like the smell of it, despite me having done new colling fluids Oct 2011
checked dipstick all looked good on there!!
checked oil filler cap, looked like moisture on there!! however its winter here, and the jeep stands outside
so pulled out that other little stick thing inside the oilfiller neck, and there it sits
Mayonnaise/Yogurt what every you wish to call it!!
that tells me head gasket!!
fell free to tell me if you dont agree!!
NOW!!
do I do just the top - gaskets and send the heads in, in other words, just a top reconditioning/overall
or
take the plunge and spend the extra money and do the whole motor, bearing, pistons/or maybe just rings
milage, unsure as the electronics were changed before I bought the vehicle, and the milage displayed is not a true indication
the motor did have a problem of valve stem seals or guides before
however all indications were that the bottom was pretty solid, no noises coming from the bottom either!!
had one or two noisy lifter in the mornings(for about 1min), after that all was smooth and quiet
so let hear all comments and advice
thanx
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #2 of 12 Old 07-14-2013, 10:06 PM
shockracer
What are your plans with it in the future? If you only plan to keep it for a year or so just do the heads. If you are planning to keep it for a longer time and keep it completely reliable do a full rebuild. Standing water doesn't do good on any metal.
Good luck with what you do!
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #3 of 12 Old 07-15-2013, 06:11 AM
Double E
Double E's Avatar
HOLD ON! You may not have a problem at all. The buildup of a creamy-brown substance in the oil fill neck is normal and not an issue. Especially if oil on the dipstick is OK.
Read: http://www.jeepforum.com/forum/f13/u...advice-223014/
The definitive answer would be a pressure check of the radiator & compression check. Do that first before calling it toast.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 12 Old 07-16-2013, 01:00 PM Thread Starter
kfxnando
Plan is to kept the jeep for a very long ti me
Doble ee, now that info puts a whole different spin on the situation
Thanx very very much for the info
Still reading the link that you send me
Very interesting
Nearly pulled theheads off for nothing
Thing is its the 1st time I noticed
kfxnando is offline
post #5 of 12 Old 07-16-2013, 01:06 PM Thread Starter
kfxnando
So far from what i have read, did do a lot of short trips begining oftne year and thefiller neck has been off when I took the valve cover off to replace a lifter and put the rocker back into place, will need to check all tnat for leecks
kfxnando is offline
post #6 of 12 Old 07-16-2013, 07:24 PM
Double E
Double E's Avatar
Good. Glad to assist from across the pond. If the oil change you do (now) indicates good oil, keep truckin. Next time the temp goes up, kill the A/C & run the heat to determine that the radiator is the issue. If it does not change, there's a leak or the water pump is an issue.
My feeling is that it's the radiator but there's no immediate issue as long as the oil change (now? right?) shows no milky issue.
Double E is offline
post #7 of 12 Old 07-16-2013, 11:55 PM Thread Starter
kfxnando
On the heat issue, seriously considering changes changing the thermostats and new antifreez again
kfxnando is offline
post #8 of 12 Old 07-17-2013, 06:35 AM
Double E
Double E's Avatar
I would just to oil/filter first to confirm there's no mixing. No point in emptying antifreeze and replacing a thermostat if the bigger problem is elsewhere, right?
Also, the thermostat housing was not really designed to be taken apart repeatedly and the bolts that hold it on are known to snap off due to poor design and difficult access. If you have a bad thermostat, the temp will not return to normal no matter what you do.
Double E is offline
post #9 of 12 Old 07-18-2013, 09:39 AM Thread Starter
kfxnando
Thanx
Do plan on doing oil and filter
Was very lucky to meet someone localy that works in an oil lab
And for a small price he can analise the oil, and see if there is any antyfreez in the oil
kfxnando is offline
post #10 of 12 Old 07-18-2013, 05:45 PM
Turbozcs2003
What year WJ
What kind of oil do you use, some have a lot of sodium as additive, so it looks like coolant leak.
Have you had to add coolant?
How old is your fan,assuming electric or do you have hydraulic.how old is the radiator.
Doing an oil sample will confirm if your loosing coolant into oil.
Turbozcs2003 is offline
post #11 of 12 Old 10-14-2013, 07:44 AM Thread Starter
kfxnando
This story is not over
Sadly
Motlr is hydro-lockeding
Either its fuel from a leeking injector or water past thd gaskets
Oil staying clean
Meantime fuel pump packed up, so to move the jeep connected an external fuel pump, that belongs to another project to feed fuel to the fuelrail tl be able to build structure for carport
Jeep had been standing for 3 weeks, and when I tried to start it it sounded like hydrolocked
Turned it by hand/ratched and could hear the fluid leaking towards the front, once it was free, it cranked free
Sunday needed to move jeep again and again hydrolocked
Hence the video
However sparkplug looks clean
Oil is also still clean
Havent changed oil yet!! Jeep has been standing while I build
Here is the video
Though I would of seen something coming out, however nothing, and the sparkplug, looks clean no rust
https://www.youtube.com/watch?v=cKnJhlLCdCg
Sadly, from where I stand, think at least on head is comming off
Advice and comments welcome
kfxnando is offline
post #12 of 12 Old 10-15-2013, 07:20 AM Thread Starter
kfxnando
Sure there are lots with advice who were faced wih similar situatons
kfxnando is offline
