4.7 timing chain help - JeepForum.com
post #1 of 4 Old 08-06-2011, 02:29 PM Thread Starter
ed1138
'99 4.7 Just did complete over haul. Had knock,upper right front side. removed front cover and valve cover. turning engine by hand ,I notice right secondary chain goes loose on top side when a cam lobe crosses center and snaps cam snaps forward a little. Chain then slaps against upper guide and makes the knock. engine runs,timing ok tensioner working . Any Ideas. Thanks
ed1138 is offline
post #2 of 4 Old 08-06-2011, 05:00 PM
marteld
mine does the same thing every once in awhile it goes away and comes back any simple fix for this?
marteld is offline
post #3 of 4 Old 08-06-2011, 10:41 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Ii edited your title to reflect the actual content. In the future please use a title that applies to the content.
More people will help.
ratmonkey is offline
post #4 of 4 Old 08-07-2011, 05:51 AM
narnwv
narnwv's Avatar
are these new chains + tensioners?
~Aaron
narnwv is offline
2000 4.7L timing chain hillaagsa WJ Grand Cherokee Forum 12 05-09-2013 02:49 PM
Timing chain 2004 WJ v8 4.7 (was: wj) skidly WJ Grand Cherokee Forum 4 04-27-2011 11:19 PM
4.7HO Timing Chain Tensioner Apollo21 WJ Grand Cherokee Forum 8 08-09-2010 04:26 AM
Timing chain replacement 03GCherokee WJ Grand Cherokee Forum 12 07-21-2010 07:56 PM
Timing belt or chain sdjwm001 WJ Grand Cherokee Forum 2 04-10-2003 05:11 AM
