4.7 power steering rebuild kit - JeepForum.com
post #1 of 10 Old 11-11-2013, 04:17 PM Thread Starter
redgrandv8
Hey, I was wondering if any of you knew if this rebuild kit would actually work? It is only 18 bucks and I feel that that is a lot better than spending 100-300 on a brand new one. Any help would be appreciated. I have the tools to do it was just wondering if it would work.
This is the kit:
http://www.stockwiseauto.com/product...FaQ9Qgoduw4A9A
redgrandv8 is offline
post #2 of 10 Old 11-12-2013, 07:43 PM
86cj74.2L
86cj74.2L's Avatar
All that is is a bearing, seal, and some o-rings.
No vanes for the pump impeller.
86cj74.2L is offline
post #3 of 10 Old 11-12-2013, 10:33 PM Thread Starter
redgrandv8
yeah but mine just squeels bad and leaks, wouldnt that fix it? or do i need all new stuff?
post #4 of 10 Old 11-13-2013, 03:23 AM
86cj74.2L
86cj74.2L's Avatar
You can try it.
As bill discovered the high pressure line o-ring can leak and cause it to look like other leaks.
post #5 of 10 Old 11-13-2013, 09:18 AM Thread Starter
redgrandv8
ah i see. alright ill try it just cuz its 18 bucks can only not fix it haha. thanks man!
post #6 of 10 Old 11-16-2013, 05:39 PM
link375
check this hose and see if that's where its leaking, if so you will have to replace the hose as well
link375 is offline
post #7 of 10 Old 11-17-2013, 02:09 PM Thread Starter
redgrandv8
Yeah I know that all my hoses are leaking where they meet the pump, and it makes that terrible whinning noise. I mainly want that whine gone haha.
post #8 of 10 Old 11-17-2013, 04:33 PM
86cj74.2L
86cj74.2L's Avatar
That could simply be air in the system from the leaks depending where they are.
post #9 of 10 Old 11-21-2013, 11:32 PM
link375
the whining noise is because of...
A. low fluid
B. air in the system
if the hose is leaking as shown in the video you have to replace the hose, a new O ring won't fix it, I tried to just replace the O ring on mine and it didn't work, I also tried to patch it up.. but the high pressure destroyed the patch.
the only solution is a new hose. there's a link in the video description to where I bought it from
link375 is offline
post #10 of 10 Old 11-22-2013, 12:02 AM
car5car
2002 M-38
I used probably 5 brake cleaner cans until I found problem, high pressure hose, I'll replace it tomorrow.
01 XJ 2wd 4.0
car5car is offline
