4.7 HO overheating and rough idle - JeepForum.com
post #1 of 38 Old 07-09-2014, 08:28 PM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
I have a 2004 Limited with about 110K miles. I've had it for about 3 years and 40K miles, with no overheating issues.
Started overheating after towing the boat (3K lbs) for about 3.5 hours last weekend. I caught it before it got too hot and was able to bring it back down with the heater.
Ran ok most of this week, even towing short distances, but started idling roughly over the last couple of days. And started running hot again in traffic (without the boat) today. The reservoir looked a bit low, and I have been able to add about a gallon of distilled water split evenly between the reservoir and directly into the radiator. The top hose is soft when it's cold. No foaming around the oil filler. And no clear signs of leaking. The fan seems to be operating properly, but it's hard to tell for certain. I think that I've heard some gurgling sounds from the heater core, but I'm not positive about that.
Any ideas before I take it into the out-of-town dealer tomorrow?
Knoxes is offline
post #2 of 38 Old 07-10-2014, 12:21 AM
OregonOverland
Short of diagnostics, you can try a computer reboot
Did you get any codes? You might try disconnecting the negative battery cable, but then it would erase any codes helpful to the techs.
Happiness in our lives consists not in the absence but in the mastery of our passions.
-Sir Alfred Lord Tennyson
OregonOverland is offline
post #3 of 38 Old 07-10-2014, 05:09 AM
pdpunome
Check passenger floor for wetness. If you have a radiator pressure tester that would expose a leak. Pull all of your plugs. I just had one in I serviced for overheating and it came down to a broken spark plug because the diy'er put two wrong plugs in.
Also I would add coolant not just water as the 4.7s are very sensitive to heat.
If you have a compression tester that would expose a blown head gasket.
Tools would be under 100 which is one hr of labor at a dealer so savings is dramatic in comparison to get the tools and test yourself.
2000 4.0 Selec Trac
pdpunome is offline
post #4 of 38 Old 07-10-2014, 05:32 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
Not getting any CELs. And the passenger floor is dry.
Knoxes is offline
post #5 of 38 Old 07-10-2014, 07:20 AM
capthowdy575
Pull the plugs check for coolant on plugs also go to autozone and rent a test kit to see if you have exhaust gas mixing with your coolant. If you have any of these it's means you have a bad head gasket or a crack head. More likely a bad gasket. Also don't overheat our let it even get to hot or you will wrap your heads and they don't have a lot of tolerance so they really can't be machined.
capthowdy575 is offline
post #6 of 38 Old 07-10-2014, 08:01 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
It just threw a Cylinder 1 misfire on the way to the dealer. It's in their hands for now...
Knoxes is offline
post #7 of 38 Old 07-10-2014, 08:10 AM
capthowdy575
By threw a cylinder you mean it came out the block our the cylinder started to knock. Also if you want to sell it let me know
post #8 of 38 Old 07-10-2014, 08:32 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
threw a Cylinder 1 misfire=Check engine light
Knoxes is offline
post #9 of 38 Old 07-10-2014, 10:06 AM
capthowdy575
Usually when people say threw a cylinder it's means that the actually cylinder is off the crank our bad journal bearings. The misfire is probably due to coolant fouling your plugs
post #10 of 38 Old 07-10-2014, 10:13 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I had a similar issue lately with an unsolvable one: rough idle, loss of power, overheating, etc. Turned out to be the catalytic converter. It wasn't showing a code for it cuz the vehicle wasn't running.
D3<!L!>3D
S8NNG8 is offline
post #11 of 38 Old 07-10-2014, 10:15 AM
capthowdy575
To check the cats start the car and take a temp prob and read both cats at normal operating temp check the fsm to see which they should be
post #12 of 38 Old 07-10-2014, 10:51 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
The dealer has been pretty good so far. Their communication and methodology seems pretty solid. We both think that the water pump was replaced at some point by the PO. It's possible that the thermostat is bad, but I think that's unlikely because it does eventually cool down when you crank the heat on or get moving.
They are going to do a dye test now to see if any gas is getting into the coolant. That ought to be a pretty definitive test.
I had considered the cats, but I think it's unlikely to have caused the misfire. And it runs solid once the rpms gain above the idle.
Actually just occurred to me that we didn't talk about pressure testing the system. Just left them a message about that.
Knoxes is offline
post #13 of 38 Old 07-10-2014, 05:02 PM
capthowdy575
Well I hope for the easiest and cheapest fix
post #14 of 38 Old 07-11-2014, 10:11 AM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
It's the head gasket. Fuel in the coolant.
Estimate is $1300 if it's just the gaskets. If the heads are warped, it's $900 for one side and $1300 for the other. They are mulling over an offer for it as is, but I'm expecting a low ball. I could tow it home and have a go at it myself. Not sure how difficult it is or what those costs look like.
Knoxes is offline
post #15 of 38 Old 09-01-2014, 08:43 PM Thread Starter
Knoxes
Knoxes's Avatar
2011 WK
I rebuilt the top end. Had the heads decked .010, basic valve job, new gaskets, new water pump, some hoses, belt, etc. It's running fine, but seems to be running just a bit hot - hasn't really gotten over the 210 mark (maybe slightly), and seems to hold there even when left idling for some time. On the freeway, it's solidly below 210 - probably right on the 195 mark for the thermostat. But I'm not entirely sure that it's cooling properly. After the initial 2 hour drive home from the rebuild, it seems to have taken a bit more coolant from the reservoir. Concerned that I still have some problems here.
Knoxes is offline
