4.7 HO head gasket ? - JeepForum.com
post #1 of 7 Old 12-18-2010, 09:40 PM Thread Starter
scottw1215
i have a 04' 4.7 HO Jeep Grand Cherokee with head gasket problem . Thinking about shaving the heads and was wondering how much can be taken off if any?
Thanks
scottw1215 is offline
post #2 of 7 Old 12-19-2010, 08:16 AM
MrBaz
HO already runs 9.7:1. You sure you want to up the compression?
2004 Charcoal Limited, 4.7L H.O., QuadraDrive, Nav
MrBaz is offline
post #3 of 7 Old 12-19-2010, 08:34 AM
hxcjohnny
you could have them decked, just to make sure they're true, then just run a thicker headgasket right?
02 WJ Overland
hxcjohnny is offline
post #4 of 7 Old 12-19-2010, 10:17 AM
outlaw30
depends on how bad they're warped. If it was a bad overheat, I doubt you'd be able to deck them and get a thick enough head gasket to keep the comp ratio close enough
outlaw30 is offline
post #5 of 7 Old 12-19-2010, 12:30 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
The 4.7HO runs fine on regular at 9.7:1. I would bet with a slight decking you would be fine but would have to run premium all the time.
~Richard
billzcat1 is offline
post #6 of 7 Old 12-19-2010, 07:41 PM
MrBaz
Most people get knock with regular on the HO. It 'runs fine' because it retards the timing due to the knock sensors and gives you less performance. Midgrade or higher is required for best performance.
MrBaz is offline
post #7 of 7 Old 12-19-2010, 08:23 PM
WiCkeDuDe
WiCkeDuDe's Avatar
I just rebuilt a HO and took 5 thousands off the deck. It only bumped it up to about 9.8, which is nothing. My other 4.7 I built up at 10.5 to 1 and it wont even run on premium without alot of work. Airram.com has the cometic head gaskets and can get any width you need, but they are PRICEY. Just shaving the heads a bit or the block wont due enough to warrant head gasket changes though.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 11:49 AM
Which head gasket? drespecki ZJ Grand Cherokee Forum 1 03-17-2009 07:56 PM
Will a cracked head or head gasket...... jpl ZJ Grand Cherokee Forum 2 03-04-2009 09:35 AM
head gasket times ZJ Grand Cherokee Forum 1 01-04-2007 10:49 PM
5.2L head gasket job... Jose's Limited ZJ Grand Cherokee Forum 4 02-01-2006 08:49 PM
