4.7 Engine rebuild question: How to remove crankshaft with engine inside? - Page 5 - JeepForum.com
post #61 of 63 Old 10-28-2013, 10:29 AM
rdkendrick
2003 WJ
Leon, did you finish your rebuild, or are you just too busy? I was really interested in seeing the rebuild in stages.
Sent from my iPad using my fingers
rdkendrick is offline
post #62 of 63 Old 10-28-2013, 10:49 AM Thread Starter
leonhuang
Hi Rdkendrick, I finished the engine rebuild. I am installing the engine back to the jeep. The problem I am facing now is i could not connect the engine block with the transmission. There is a small gap about <1cm in betweem. The reason is only driver side short-stick on the block get into the hole on transmission case, the "starter" side, i could not get it into the hole. I may need to use hydro jack under the engine and transmission to adjust the position a little bit. I was also suggested to turn/push the torque converter back in, coz it may have fallen out a bit...
Any suggestions?Thanks!
leonhuang is offline
post #63 of 63 Old 10-28-2013, 08:15 PM
WJHahn
On mine I had to support the engine with my hoist and the trans with a jack. Play with the angles (looking under and on top) and twist and push and it'll eventually go in unless you have something blocking it. DO NOT try to bolt it into place.
WJHahn is offline
