4.7 Engine pulling tips and questions - JeepForum.com
post #1 of 8 Old 03-04-2014, 09:55 AM Thread Starter
Coloradoyj1
Hey Guys,
On to my second WJ (01 limited w/v8) she has 134k and the motor got hot so I need to swap it out. I had a couple quick questions, see below, as well as looking for some general pointers for people that have done this job that will make things a little smoother
questions:
RELEASING FUEL pressure: the manual says to turn the motor over with injectors removed, this motor is seized so I can't do that, I am worried about the amount of pressure in the system and how best to release it.
I noticed some people remove the radiator? is this necessary?
I plan on pulling the motor sometime this weekend, and would love to get some pointers that could help with my first engine pull. thanks guys!
95 yj 4.0
90 xj 4.0
03 discovery s
Coloradoyj1 is offline
post #2 of 8 Old 03-04-2014, 11:04 AM
stone white 99
Definitely remove the radiator and condenser. Good time to replace either if old.
I found the very top two trans-to-engine bolts to be 16mm and only accessible from the top side laying over the engine using a gear wrench. The next two down the bellhousing I got using a long extensions and u joint in there/ electric impact.
Starter out, exhaust off at manifold and remove exhaust to trans mount.
Then you can remove the structural cover dont forget to loosen and remove the four flex plate to torque converter bolts up in there. You will need a harmonic balance puller and install tool.
Remember you will have to pre prime the oiling system if new engine before first start up or you could turn your bearings to dust.
Find a complete writeup if you can.
Releasing fuel pressure done at fuel rail.
stone white 99 is offline
post #3 of 8 Old 03-04-2014, 11:20 AM
Double E
Double E's Avatar
Disconnect fuel filter & release pressure at Schrader valve on fuel rail?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 8 Old 03-04-2014, 12:18 PM
Johnyre
x2 on the fuel rail. You should find it at the end on the fuel rail
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #5 of 8 Old 03-04-2014, 09:55 PM
mycreativename
Rather than worry about separating engine from transmission while still attached in the vehicle, pull the entire assembly out through the front and disassemble it outside the Jeep.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #6 of 8 Old 03-04-2014, 10:02 PM
capthowdy575
first will you be using a lift? if not I would deflate your front tires yes it sound crazy but it just makes it a little easier to pull the motor out if your not using a super tall hoist. also the fuel rail only holds about 45psi which isn't much. take a thick rag and look at the pass side fuel rail should be a little cap take it off cover the hole and press in with a screw driver. also remove the rad cond and air box, front grill cover. also pics would be awesome lol. good luck
capthowdy575 is online now
post #7 of 8 Old 03-04-2014, 10:11 PM
Nbrown08
X2 i've pulled mine twice and did it this way the second time.
Pulled the driveshaft the dropped the crossmember. It's one big assembly lol
Nbrown08 is offline
post #8 of 8 Old 03-05-2014, 10:21 AM Thread Starter
Coloradoyj1
Thanks Guys!
I appreciate the insight, I haven't bought my hoist yet, but when I worked in a shop we always pulled the motor/trans together. I'll get a write up going because I haven't seen one on the forum, Morris 4x4 has the factory manuals on line which has been a good starting point. Thanks again, excited to be riding in a plush jeep again.
95 yj 4.0
90 xj 4.0
03 discovery s
